How to read output port?
I need to read state of some output ports in my application.
In some part of the program I write these ports and in other part I want to read actual state and I wouldn't like to use special variables to keep the states.
I cannot quite understand the "tristate" meaning in Altera peripheral handbook, but it seems to me that this is what I need. I already have tested it (with first setting the direction of the port to 1 to become tristate) and it seems to be working fine. Since I don't fully understand the datasheet explanation, can somebody please confirm that I am doing it right and not setting something else, which can eventually cause some problems in my application?
Peripheral handbook says this:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Bidirectional (tristate) ports:
In this mode, each PIO bit shares one device pin for driving and capturing data.
The direction of each pin is individually selectable. To tristate an FPGA I/O pin, set
the direction to input.[/b]
--- Quote End ---
there are two cases for ports:
1. port signals are connected to real in/outputs of fpga
( i think it&#39;s ok to use tristate signals to read back the setting of
the outputs)
2. port signals are used internal in fpga
(tristate does not make sense, I don&#39;t know if quartus syntesizes
tristate registers away ?)
because I had some signals with case 2 and also wanted to read back
the settings of the outputs, i made ports with input and output
(no tristate) and connected in/outputs of these ports together
in the top schematic.
perhaps someone from altera can explain what will happen if i use tristate for
internal port signals ?
