If I want to put software program elf file into flash, then the system can load program automatically after power on, I think I need to add a flash controller in my qsys system, correct? Is Altera Avalon Flash the right IP I should use/
Thanks.Link Copied
Anyone has idea?
Thanks in advance.- Mark as New
ok i am working on the same project , i am a beginner , i used the avalon tristate conduit components , but dunno whether it is the answer ,
in any way this links will answer you too http://www.alteraforum.com/forum/showthread.php?t=44414&highlight=flash :oops: sincerely ,- Mark as New
Nobody has experience?
Altera supplies some libraries for writing the epcs/epcq devices from software if the avalon epcs controller IP is instantiated. One way to discover the correct elf offset is to run elf2flash with the --after option.
--- Quote Start --- Altera supplies some libraries for writing the epcs/epcq devices from software if the avalon epcs controller IP is instantiated. One way to discover the correct elf offset is to run elf2flash with the --after option. --- Quote End --- Thanks. Do you mean "EPCS Serial Flash Controller Core"?
--- Quote Start --- Thanks. Do you mean "EPCS Serial Flash Controller Core"? --- Quote End --- yes, that's the one we use here
--- Quote Start --- yes, that's the one we use here --- Quote End --- Thanks very much.
Topic Options
