12689 Discussions
Installation of Quartus v13.1 message - "You must install 32 bit "libstdc++" library
I’ downloaded the “Complete Download” :
Quartus II Subscription Edition Software (Device support included)
Quartus-13.1.0.162-linux-complete.tar
After "untaring" and launching “setup.sh” – I’ got the following message:
> ./setup.sh
You must install the 32-bit version of the following libraries for the Quartus II installer and software to operate properly:
> libstdc++
If you proceed with the installation your software may not function correctly.
*****************************************************************************************************8
By running the following command: > rpm -q libstdc++
I got: > libstdc++-4.1.2-48.el5
Is there a specific version of libstdc++ that should be installed?
Thank you in advance.
You have to install the 32-bit compatibility libraries on a 64-bit system. They're distro-specific and should be easy to install. What OS are you attempting to install to?
Hi Ginna
Read the following link:
http://rocketboards.org/foswiki/documentation/gsrdgettingstartedyocto
Zs.V.
