Interrupt driven UART
Hello everybody,
I'm a NIOS II beginner and I'm having trouble in finding an example how to code an interrupt driven UART application where I can send and receive commands from a camera I have interfaced to the cyclone board RS232 serial port.
I would be grateful for any help
This is non HAL code in NIOS1 but it is currently working fine in NIOS2 as well
include
# include "excalibur.h"
global
//Make sure you have a uart in excalibur.h that matches your uart name (na_uartxxxx)
np_uart *uart1 = (np_uart *)na_uart_1;
init the uart
void uart1_setup(void)
//UART 1 setup -----------------------
uart1->np_uartstatus = 0; // clear the interrupt condition
nr_installuserisr(na_uart_1_irq ,UART1_ISR,(int)uart1);
uart1->np_uartcontrol=0;
uart1->np_uartcontrol = uart1->np_uartcontrol | (np_uartcontrol_irrdy_mask);
irq routine
void UART1_ISR(int context)
np_uart *uart1 = (np_uart *)context;
int status;
unsigned char rxChar;
status = uart1->np_uartstatus;
rxChar = (unsigned char)uart1->np_uartrxdata;
if(status & np_uartstatus_rrdy_mask) // character arrived?
// Write code to handle rxchar
if(status & np_uartstatus_trdy_mask) // character arrived?
if (more bytes to transmit?)
// Write code to send next byte
uart1->np_uarttxdata=next byte
else
// Set the port to read only
uart1->np_uartcontrol = np_uartcontrol_irrdy_mask; //only Rx enable (if half duplex)
to start a transmit sequence start by sending a byte and then enabling the Tx IRQ flag.
uart1->np_uarttxdata=tx1_buffer[0]; // send first byte. IRQ will do the rest
uart1->np_uartcontrol =np_uartcontrol_itrdy_mask; // only Tx enable
you can have rx irq flag enabled all the time for full duplex. Just write your code to handle it.
First use a fix baud rate (as defined in SOPC builder) before playing with your own software settings. Fix baud rates uses less LEs.
to test connect the 2 pins (Tx,Rx) either in software or hardware and send a few bytes and return the status with a printf or 2.
To make life easier implement a ring buffer for the received character and parse it outside the irq. Don't put too much inside the IRQ routine. Just grab and store.
Victor
http://www.zerksus.com (http://www.zerksus.com)
