Isp1362
Hello everybody !
Does anybody manage to make the isp1362 run under uCLinux with the OTG port configure as un host port? I'm working on Cyclone3 board FPGA ALTERA DEV board.
I have took the DE2 board schematic and created a small SantaCruz board.I have change some pins connexions :
-> OTGMODE connect to a pullup 3.3V through a 4.7kOhm
-> ID to pulldown through a 4.7kOhm
I have commented (as I found in the forum) every line of the function isp1362_hc_reset in isp1362-hcd.c.
Plus, I have commented those following line in the isp1362_hc_start function :
if ((chipid & HCCHIPID_MASK) != HCCHIPID_MAGIC) { pr_err("%s: Invalid chip ID %04x\n", __func__, chipid); return -ENODEV; } When I boot the board I have those lines :
usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 10, io mem 0x00000050 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 10 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 1672k freed (0xc26c000 - 0xc40d000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc -o noexec,nosuid,nodev Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev hub 1-0:1.0: unable to enumerate USB device on port 1 And then, I can't have access to my USB memory device.
Does anyone can help me.
Thanks in advance
Does anybody manage to access to a USB stick through an ISP 1362/1761 ? Did you do it on your own board, on a DE2 Board ?
Here is my schematic.
All the OTG signal are connected to the isp1362 interface execpt OTG_DREQ0 and OTG_DREQ1.
CLKIN is connected to a PLL output wich generate an 12MHz signal.
Question : How the Nios manage the data transfert to the isp ? they are not on the same clock domain : the isp is 12 MHz and my Nios is 120MHz ?
Thanks is advance.
(Virus scan in progress ...)
--- Quote Start ---
--- Quote End ---
The NIOS example design uses several clock domains on the Avalon bus. This is said to speed up the design greatly.
You can use an Avalon bus bridge to cross a clock domain. The avalon bus at the other site of the bridge will be connected to the I/O pins with a standard appropriate bus I/O or with your own Avalon slave design.
-Michael
That's mean that the isp1362 ic and his interface (sopc component) must have the same clock ?
I don't need to add an delay (phase) between the 12MHz isp1362 and 12MHz FPGA ?
Does anybody who manage to make usb master work on the DE2 could answer me ?
thanks !
Hi all,
Now I get this message after boot :
hub 1-0:1.0: connect-debounce failed, port 1 disabled
Does anybody got ideas ?
After re-reading the ISP1362 documentation I've understood that the FPGA-ISP bus is an asynchronous bus. That the reason why the ISP can run at 12MHz (external clock, internal : 48MHz) and the FPGA on other clock domain (100 MHz for my design).
I've try to make the USB Host up and running on the DE2, however, I didn't manage does anybody got an idea ?
The DMESG is
uClinux/Nios II Built 1 zonelists in Zone order, mobility grouping off. Total pages: 16256 Kernel command line: NR_IRQS:32 PID hash table entries: 256 (order: 8, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory available: 60788k/4170k RAM, 0k/0k ROM (2088k kernel code, 2082k data) Calibrating delay loop... 41.88 BogoMIPS (lpj=209408) Mount-cache hash table entries: 512 net_namespace: 264 bytes NET: Registered protocol family 16 init_BSP(): registering device resources bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 io scheduler noop registered io scheduler deadline registered (default) ttyJ0 at MMIO 0x10022c98 (irq = 2) is a Altera JTAG UART console enabled ttyS0 at MMIO 0x10000000 (irq = 6) is a Altera UART ttyS1 at MMIO 0x10000020 (irq = 7) is a Altera UART usbcore: registered new interface driver ub Driver 'sd' needs updating - please use bus_type methods 0 : New Bus ID Altera TSE MII Bus: probed Found phy with ID=0x1410cc2 at address=0x12 Altera TSE MII Bus: MDIO Bus Registered Altera Triple Speed MAC IP Driver(v8.0) developed by SLS,August-2008,--Linux 2.6.27-rc3 usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd: irq 10, io mem 0x10000050 isp1362_hc_start: isp1362_hc_start: Invalid chip ID 0027 isp1362-hcd isp1362-hcd: startup error -19 isp1362-hcd isp1362-hcd: USB bus 1 deregistered isp1362_probe: init error, -19 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 1672k freed (0xc270000 - 0xc411000) Shell invoked to run file: /etc/rc
