12690 Discussions
Lancelot reference designs for Stratix 1s40
Im using a Nios II Stratix professional edition (1s40) developrment board, and i can't find the Lancelot reference designs for it. The only ones on the www.fpga.nl website are for the 1s10 and cyclone. Does anyone have any ideas about what i could do?
thanks
Deeps
Open the 1s10 design in Quartus, go to Assign -> Device, and select the 1S40 (be specific about the package type/pin count'/speed grade). When prompted if you want to remove location assignments select NO. Then re-compile in Quartus.
Background: The 1s10, 1s10ES, and 1s40 Nios development boards all have the exact same pinouts, the only thing that needs to be changed is the device assignment. This is *not* true of the 1C20 board so be careful!
