12747 Discussions
Literature about embedded Linux
Hi Friends!
I'm a beginner in using embedded Linux and so I'm looking for a literature about embedded Linux.
The main issues in such a book should be:
-Develop software (device driver, applications) for eL.
-Kernel modification.
-Booting eL.
-Debugging on eL.
-Real-world interfacing with eL.
-Root filesystem creation.
-Using serial, parallel, memory I/O, USB, graphic displays and interrupt-driven hardware.
A book like this is "Embedded Linux" written by Craig Hollabaugh.
But it's include only x86, StrongARM and PowerPC as examples of platforms, not Nios.
Should I make the compromise to buy it or
does somebody knows a better book?
Bye, Lothar.
--- Quote Start ---
originally posted by maico+dec 1 2005, 10:43 am--><div class='quotetop'>quote (maico @ dec 1 2005, 10:43 am)</div>
--- quote start ---
i&#39;m a beginner in using embedded linux and so i&#39;m looking for a literature about embedded linux.
the main issues in such a book should be:
-develop software (device driver, applications) for el.[/b]
--- quote end ---
the autobook for user level applications (gnu/autotools). can be read on the net or bought on e.g. amazon.
--- quote start ---
originally posted by maico@dec 1 2005, 10:43 am
-kernel modification.
--- quote end ---
o&#39;reilly has 2 good books about this one; one about the kernel and one about device drivers; check their site or amazon
--- quote start ---
-booting el.
--- quote end ---
e.g. wolfgang denk&#39;s das u-boot; he maintains a good portion of documentation on his bootloader.
--- quote start ---
-debugging on el.
--- quote end ---
several resources, mainly running on gdb (ddd). i guess you&#39;ll find the most documentation about this on the net.
--- quote start ---
-real-world interfacing with el.
-root filesystem creation.
--- quote end ---
depends on what you&#39;re doing; but checking buildroot might be a good start; for a nios fs, you need little more than the basic directory structure and the device nodes (you should not use devfs, since it&#39;s being ripped out in the later kernels).
--- quote start ---
-using serial, parallel, memory i/o, usb, graphic displays and interrupt-driven hardware.
--- quote end ---
check the o&#39;reilly books...
<!--quotebegin-maico@Dec 1 2005, 10:43 AM
a book like this is "embedded linux" written by craig hollabaugh.
--- Quote End ---
I think O&#39;Reilly has one titled &#39;embedded systems&#39;; a very good book.
--- Quote Start ---
originally posted by maico@Dec 1 2005, 10:43 AM
but it&#39;s include only x86, strongarm and powerpc as examples of platforms, not nios.
should i make the compromise to buy it or
--- Quote End ---
I don&#39;t think you&#39;ll find better resources on Nios II; since it is not, and will likely never be, a very wide spread and accepted solution for (uC)Linux; Altera ppl actually say this in between the lines.
Hello Marc!
Thank you, for your detailed answer.
I&#39;ve bought "Linux Devices Drivers" and "Building Embedded Linux Systems" from O&#39;Reilly.
I will check your other hints too.
At the moment I&#39;m intensely working with "Linux Devices Drivers".
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
I don&#39;t think you&#39;ll find better resources on Nios II; since it is not, and will likely never be, a very wide spread and accepted solution for (uC)Linux; Altera ppl actually say this in between the lines.[/b]
--- Quote End ---
Do Altera mention any reason why Nios II will probably never be a very wide spread and accepted solution for µLinux?
Bye, Lothar.
