12699 Discussions
Loading image to SDRAM under ubuntu
I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like
alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
/opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory
Where is the mistake?
Thanks in advance.
My guess is that you need to add the quartus library directory containing the required so files to the LD_LIBRARY_PATH variable.
For Quartus v12.0 it should be located in <path-to-quartus>/12.0/quartus/linux64 where <path-to-quartus> depends on where you installed the software.
Try this:
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<path-to-quartus>/12.0/quartus/linux64; nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
N.
Thanks for ur reply sir,but i executed the nios2-download command its showing like this
there is a problem with the quartus ii installation on your computer.
please use `jtagconfig` for further diagnosis.
Kindly any help?
Alex.
Can you try executing that command as root? Just to check if it's a permission issue.
N.
Thanks you sir, tried as root but.......
alex@alex:~$ sudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
[sudo] password for alex: *****
sudo: nios2-download: command not found
alex@alex:~$ gksudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
here it doesnt show any error but no output,just it return to command prompt
alex@alex:~$ gksudo ./nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
here also it doesnt show any error but no output,just it return to command prompt
Else i have to check like this or any other method?
Alex.
Sir,
For suppose if i got error like this (As mentioned below)
I came to know, i have to kill jtagd as mentioned below
$ sudo killall jtagd
$ sudo /opt/quartus/bin/jtagconfig -n
Is it true?
what i have to do?
Kindly any help?
Try the following command to see if it resolves the jtag issue for normal users:
echo 'ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="666"' | sudo tee -a /lib/udev/rules.d/51-usbblaster.rules
Reboot your machine just to make sure it takes effect.
N.
Thanks for giving replies
still iam strucking there only
Sir, once i close and again i open my terminal,
if i type donload command
1.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
then i typed
2.alex@alex:~$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/quartus/linux and press enter
alex@alex:~$
3.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage
i added the your line as u mentioned in the previous post
And finally in my 51-usbblaster rules file is like this
#usb-blaster
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6001", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6002", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6003", mode="0666"
echo 'attr{idvendor}=="09fb", attr{idproduct}=="6001", mode="666"'
Y , once i close my terminal ,again i will open na no library path.
I have to fix this problem, kindly any help?
Alex.
The last command I gave you was supposed to be executed only once.
In the archive attached to this post are two files:
altera.conf -> put this one in /etc/ld.so.conf.d (this way you don't have to export the library path every time)
51-usbblaster.rules -> put this one in /lib/udev/rules.d
Reboot your machine and try again.
N.
(Virus scan in progress ...)
Sir,
My usb blaster rules it is in /etc/udev/rules.d/51-usbblaster.rules,can i delete this one, imean as showed in my previous post
According to you , i have to place /lib/udev/rules.d, in my path(/etc/udev/rules.d/51--usbblaster.rules) this file can i delete or what?
Alex.
Yes, you can overwrite the /lib/udev/rules.d/51-usbblaster.rules you created previously with the 51-usbblaster.rules in the zip file.
N.
Also remember to put the quartus bin directory in your .bashrc file
alex@alex:~$ gedit ~/.bashrc &
and add the following line to the bottom of the file
export PATH=$PATH:/opt/quartus/bin
Then log out and log back in.
N.
I tried all the steps , as u mentioned in your previous post, but same problem, where is the mistake?
error
else cont we download the image into SDRAM under ubuntu?
Alex.
Sir,
If i open my bashrc file its showing error like this, previosuly i opend ,but at that time i dint get any error, but now....
/opt/quartus/linux/libstdc++.so.6: version `glibcxx_3.4.11' not found (required by /usr/lib/i386-linux-gnu/libproxy.so.1)
failed to load module: /usr/lib/i386-linux-gnu/gio/modules/libgiolibproxy.so
** (gedit:2404): warning **: error loading plugin: /opt/quartus/linux/libstdc++.so.6: version `glibcxx_3.4.15' not found (required by /usr/lib/libaspell.so.15)
finally my bashrc file is
# ~/.bashrc: executed by bash(1) for non-login shells.# see /usr/share/doc/bash/examples/startup-files (in the package bash-doc)# for examples
# If not running interactively, don't do anything
[ -z "$PS1" ] && return
# don't put duplicate lines or lines starting with space in the history.# See bash(1) for more options
HISTCONTROL=ignoreboth
# append to the history file, don't overwrite it
shopt -s histappend
# for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
HISTSIZE=1000
HISTFILESIZE=2000
# check the window size after each command and, if necessary,# update the values of LINES and COLUMNS.
shopt -s checkwinsize
# If set, the pattern "**" used in a pathname expansion context will# match all files and zero or more directories and subdirectories.# shopt -s globstar
# make less more friendly for non-text input files, see lesspipe(1)
[ -x /usr/bin/lesspipe ] && eval "$(SHELL=/bin/sh lesspipe)"
# set variable identifying the chroot you work in (used in the prompt below)
if [ -z "$debian_chroot" ] && [ -r /etc/debian_chroot ]; then
debian_chroot=$(cat /etc/debian_chroot)
fi
# set a fancy prompt (non-color, unless we know we "want" color)
case "$TERM" in
xterm-color) color_prompt=yes;;
esac
# uncomment for a colored prompt, if the terminal has the capability; turned# off by default to not distract the user: the focus in a terminal window# should be on the output of commands, not on the prompt# force_color_prompt=yes
if [ -n "$force_color_prompt" ]; then
if [ -x /usr/bin/tput ] && tput setaf 1 >&/dev/null; then
# We have color support; assume it's compliant with Ecma-48
# (ISO/IEC-6429). (Lack of such support is extremely rare, and such
# a case would tend to support setf rather than setaf.)
color_prompt=yes
else
color_prompt=
fi
fi
if [ "$color_prompt" = yes ]; then
PS1='${debian_chroot:+($debian_chroot)}\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w\[\033[00m\]\$ '
else
PS1='${debian_chroot:+($debian_chroot)}\u@\h:\w\$
fi
unset color_prompt force_color_prompt
# If this is an xterm set the title to user@host:dir
case "$TERM" in
xterm*|rxvt*)
PS1="\[\e]0;${debian_chroot:+($debian_chroot)}\u@\h: \w\a\]$PS1"
esac
# enable color support of ls and also add handy aliases
if [ -x /usr/bin/dircolors ]; then
test -r ~/.dircolors && eval "$(dircolors -b ~/.dircolors)" || eval "$(dircolors -b)"
alias ls='ls --color=auto'
# alias dir='dir --color=auto'
# alias vdir='vdir --color=auto'
alias grep='grep --color=auto'
alias fgrep='fgrep --color=auto'
alias egrep='egrep --color=auto'
fi
# some more ls aliases
alias ll='ls -alF'
alias la='ls -A'
alias l='ls -CF'
# Add an "alert" alias for long running commands. Use like so:# sleep 10; alert
alias alert='notify-send --urgency=low -i "$([ $? = 0 ] && echo terminal || echo error)" "$(history|tail -n1|sed -e '\''s/^\s*[0-9]\+\s*//;s/[;&|]\s*alert$//'\'')"'
# Alias definitions.# You may want to put all your additions into a separate file like# ~/.bash_aliases, instead of adding them here directly.# See /usr/share/doc/bash-doc/examples in the bash-doc package.
if [ -f ~/.bash_aliases ]; then
. ~/.bash_aliases
fi
# enable programmable completion features (you don't need to enable# this, if it's already enabled in /etc/bash.bashrc and /etc/profile# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
. /etc/bash_completion
fi# Nios II Toolchain
export PATH=$PATH:~/uClinux/Tools/opt/nios2/bin
export PATH=$PATH:/opt/nios2eds/bin
export PATH=$PATH:/opt/sopc_builder/bin
export PATH=$PATH:/opt/nios2eds/bin/gnu/H-i686-pc-linux-gnu/bin
Alex.
Are you running an old version of quartus? Perhaps you're better of reinstalling v12.0 of Quartus II?
N.
Iam using quartus 11.1 service pack, is it ok?, otherwise i have to reinstall quartus with 12v? and one more thing i have downloaded nios2-linux-20090929.tar under windows, is any problem ?
Alex.
Please do the following:
1. Open up a terminal and type "jtagconfig" followed by enter. What does it say?
2. Install libstdc++6 using the command "sudo apt-get install libstdc++6"
N.
alex@alex:~$ jtagconfig
1) USB-Blaster variant [7-1]
Unable to lock chain (Insufficient port permissions)
and i installed the libstdc++6 also, and i am using ubuntu12.04
alex.
That's exactly the kind of problem the /lib/udev/rules.d/51-usbblaster.rules file is supposed to fix.
Connect your altera device to the usb port and execute "lsusb" in a terminal. The output should contain a line like this:
Bus 003 Device 002: ID 09fb:6001 Altera Blaster
N.
Ya, the output is like .
alex@alex:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 1210:25f4 DigiTech
Bus 006 Device 002: ID 15d9:0a4c Trust International B.V. USB+PS/2 Optical Mouse
Bus 007 Device 004: ID 09fb:6001 Altera Blaster
then how to fix the problem?
Are you sure you installed the rules file correctly?
Type in "cat /lib/udev/rules.d/51-usbblaster.rules" at the command prompt. It should say:
You did reboot your machine, right?
N.
