MK4 failures
Does anybody know how NIOS2 is affected by the MK4 failures in the CycloneII as described in http://www.altera.com/literature/ds/es_cycii.pdf (http://www.altera.com/literature/ds/es_cycii.pdf) ?
Nios II itself is not affected. If you make a custom component that uses dual ported M4K blocks or some 3rd party IP that does then you will want to pay close attention to that document.
