公告
12748 讨论
MMU Custom Cyclone II make error
名誉分销商 II
1,615 次查看
I've got a custom board with a Cyclone II
I used to use an older version of nios2-linux/uClinux but decided it was time to try the MMU version. So, I downloaded the nios2-linux20100621.tar and set to work.
I could not use ./update and get the message below for all ---
[janet@localhost nios2-linux]$ ./update
update binutils..
sopc.et.ntust.edu.tw[0: 140.118.20.145]: errno=Connection timed out
fatal: unable to connect a socket (Connection timed out)
I also tried to ping 140.118.20.145, it doesn't work. Is this server down?
What could cause that I've tried lately and get that I used to get updates and I haven't done anything to my home network.
But I set to work anyway. I followed the Creating a Nios II Design with an MMUI added my board etc.
But when I do the "make" I get this "vmlinux.lds:380: syntax error
Isn't that a generated file ?? Any help will be greatly appreciated.
Thanks -
************* END OF make messages
CC init/version.o
LD init/built-in.o
LD .tmp_vmlinux1
/home/janet/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:380: ignoring invalid character `#' in expression
/home/janet/nios2-linux/toolchain-mmu/x86-linux2/bin/nios2-linux-gnu-ld:arch/nios2/kernel/vmlinux.lds:380: syntax error
make[2]: *** [.tmp_vmlinux1] Error 1
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/janet/NEWEST-nios2-linux/nios2-linux/linux-2.6'
make: *** [linux] Error 1
0 项奖励
8 回复数
名誉分销商 II
905 次查看
Didn't catch the other post --
SOLVED --->
DON'T USE // as comments !!! use /* */
0 项奖励
名誉分销商 II
905 次查看
in which files ? why ?
-Michael
0 项奖励
名誉分销商 II
905 次查看
This is the newest Linux based release. Structured differently than the previous. There is a god document "Running Linux on the "Altera Nios II Processor USER GUIDE version 1.0" that a work mate gave me (not sure where he found it).
The file is the "nios.h" that you use to reference your "custom_fpga.h" file
It's in the nios2-linux/linux-2.6/arch/nios2/boards/MYboard/include/asm
I'm still trying to get my custom driver compiled into the kernel (porting over from older nios2-linux release) -- can't find "asm/nios2.h" ... but I've been sidetracked on something else.
I hope that clarifies things.
0 项奖励
名誉分销商 II
905 次查看
When you are switching to LINUX nios2 and porting your custom drivers over
The include used to be# include <asm/nios2.h>
NOW --- # include <asm/nios.h>
No more "2"
0 项奖励
名誉分销商 II
905 次查看
I think the document you are referring to is http://alterawiki.com/uploads/e/e6/opensource_linux_niosii_user_guide_-_fixed_toc.doc
Too bad the filename does not match the title....
0 项奖励
名誉分销商 II
905 次查看
Yes, that's the document !!
It was very helpful.
0 项奖励
名誉分销商 II
905 次查看
I got an e-mail saying
Hi guys,
Do you still have the document " Running Linux on the "Altera Nios II Processor USER GUIDE version 1.0" ? If do, can you please share the link.
Thank you.
Moganesh
I don't see that on this message but the link is still good
http://alterawiki.com/uploads/e/e6/o..._fixed_toc.doc (http://alterawiki.com/uploads/e/e6/opensource_linux_niosii_user_guide_-_fixed_toc.doc) ?
0 项奖励
名誉分销商 II
905 次查看
I post it but looking back the link is still on the thread and available. The method is not same with latest nios2-linux. Thanks though.
0 项奖励
回复
