Hi all,
I am trying to use jffs2 on my custom board (an AMD CFI compliant flash). When I try to mount my CFI-compliant flash, it seems ok (no message from MTD driver with debug level 3, and it appears as mounted in /proc/mounts), but as soon as I try to access it (an 'ls' in the mounted directory, or any write access), I get a SIGSEGV, and the system never responds anything else than SIGSEGV to any command I enter. The flash I use is an S29GL256M that is correctly recognized by the flash-programmer. I have modified the mapping file to use the MTD driver, and I have created entry in the /dev dir, with the correct minor/major (I actually did exactly what I did to have a JFFS2 filesystem running ok on the Altera devboard...). Can somebody help me with this ? Thanks, podLink Copied
