12748 Discussions
Mixed source / Assembly listing
Is this possible, so I can get a fair idea on how the code for this is distributed?
0000413c <uart_irq_1>:    413c:    01421204  movi    r5,2120    4140:    29000037  ldwio    r4,0(r5)    4144:    28000035  stwio    zero,0(r5)    4148:    2006d1fa  srli    r3,r4,7    414c:    1880004c  andi    r2,r3,1    4150:    10000226  beq    r2,zero,415c <uart_irq_1+0x20>    4154:    01821004  movi    r6,2112    4158:    30c00037  ldwio    r3,0(r6)    415c:    200ed1ba  srli    r7,r4,6    4160:    3900004c  andi    r4,r7,1    4164:    20001026  beq    r4,zero,41a8 <uart_irq_1+0x6c>    4168:    d16003c3  ldbu    r5,-32753(gp)    416c:    d2200383  ldbu    r8,-32754(gp)    4170:    02800034  movhi    r10,0    4174:    52840444  addi    r10,r10,4113    4178:    2a403fcc  andi    r9,r5,255    417c:    4a85883a  add    r2,r9,r10    4180:    4a00062e  bgeu    r9,r8,419c <uart_irq_1+0x60>    4184:    13400003  ldbu    r13,0(r2)    4188:    03021104  movi    r12,2116    418c:    63400035  stwio    r13,0(r12)    4190:    2ac00044  addi    r11,r5,1    4194:    d2e003c5  stb    r11,-32753(gp)    4198:    f800283a  ret    419c:    03c02004  movi    r15,128    41a0:    03821304  movi    r14,2124    41a4:    73c00035  stwio    r15,0(r14)    41a8:    f800283a  ret
Hi Jason,
Use the objdump -S option.
--Scott
Hi Scott.
It looks as though the -S option is already used:
"OBJDUMP = nios2-elf-objdump -D -S -x"
in the file C:\altera\kits\nios2_v5\components\altera_nios2\HAL\src\component.mk
I suspect I need to turn on a "debug info" option, or to specify the "source dirs"
By adding the -l option (line numbers), i.e.
"OBJDUMP = nios2-elf-objdump -D -S -x -l"
...I was able to produce a list of line numbers in a few code sections only:
e.g. C:\altera\kits\nios2_v5\bin\nios2-gnutools\src\gcc\gcc\config\nios2\lib2-divmod.c
- not the HAL nor project source files.
So there must be something really simple I&#39;ve overlooked......
Ahaa!
The mixed source appears in the DEBUG configuration, but not in the RELEASE.
Hi Jason,
Yep, you need to make sure the -g option is passed to the compiler.
And don&#39;t strip the elf ;-)
--Scott
Hey,Scott!
I have a question maybe seems silly to you.You said mixed listing can be seen by using the objdump -s option,
but where can I set this option in NiosII IDE?
Thx
Hi yancharles,
I don&#39;t think I can help you with this one since I&#39;m an old command-line fogey ;-)
and I always run objdump from the shell.
You should however enable debugging information using the &#39;-g&#39; option. You can do this
in your project properties under C/C++ Build, Debug level.
--Scott
