12732 Discussions
NIOS II Console shows nothing
I am trying to run a very simple nios system with a timer and onchip memory with RTOS hello program using Quartus 11 and QSYS but the console shows nothing . I tried to run a hello world example but it doesn't work too.
The console shows :
Starting processor at address 0x000801B4
then nios II console shows nothing and neither does the command shell.
The onchip memory reset vector address is 0x8000000
The system is attached and I am using a pll but it only multiplies by 1.
I solved the problem by using an old project that used to work. I don't know what is the cause of this problem or when it happens.
