12627 Discussions
NIOS II access via avalon-mm to PCIe registers
I want to develop a PCI express rootport to control an endpoint PCIe card. I have used a Avalon-MM Cylone V Hard IP for PCI Express to design the rootport and a NIOS II processor to develop the driver. The problem is that I can't access to PCIe register as CRA and TXS that are interconnected to NIOS II processor with a avalon-mm interconnect bus.
After the creation of the bsp I have a system.h that only includes CRA base and TXS base addresses but doesn't include anything related with internal registers.
* pcie_cv_hip_avmm_0_Cra configuration
#define alt_module_class_pcie_cv_hip_avmm_0_cra altera_pcie_cv_hip_avmm
#define pcie_cv_hip_avmm_0_cra_base 0x20000
#define pcie_cv_hip_avmm_0_cra_irq 3
#define pcie_cv_hip_avmm_0_cra_irq_interrupt_controller_id 0
#define pcie_cv_hip_avmm_0_cra_name "/dev/pcie_cv_hip_avmm_0_cra"
#define pcie_cv_hip_avmm_0_cra_span 16384
#define pcie_cv_hip_avmm_0_cra_type "altera_pcie_cv_hip_avmm"
* pcie_cv_hip_avmm_0_Txs configuration
#define alt_module_class_pcie_cv_hip_avmm_0_txs altera_pcie_cv_hip_avmm
#define pcie_cv_hip_avmm_0_txs_base 0x20000000
#define pcie_cv_hip_avmm_0_txs_irq -1
#define pcie_cv_hip_avmm_0_txs_irq_interrupt_controller_id -1
#define pcie_cv_hip_avmm_0_txs_name "/dev/pcie_cv_hip_avmm_0_txs"
#define pcie_cv_hip_avmm_0_txs_span 536870912
#define pcie_cv_hip_avmm_0_txs_type "altera_pcie_cv_hip_avmm"
For example to access other embedded ip peripherals via NIOS II(such UARTs, PIO...), system.h includes several define for access individual registers.
Actually I am trying to send TLP packets via reg0, reg1 and control registers directly via memory mapping:
volatile int * rp_reg0 = (int *) pcie_cv_hip_avmm_0_cra_base + rp_tx_reg0 ;
volatile int * rp_reg1 = (int *) pcie_cv_hip_avmm_0_cra_base + rp_tx_reg1 ;
volatile int * rp_ctrl = (int *) pcie_cv_hip_avmm_0_cra_base + rp_tx_cntrl ;
/* 1.Write the first 32 bits of the TX TLP to RP_TX_REG0.2. Write the next 32 bits of the TX TLP to RP_TX_REG1.
3. Write the RP_TX_CNTRL.SOP to 1’b1 to push the first two dwords of the TLP into the Root Port TX FIFO*/
*(rp_reg0) = tlp_cfg_dw0(tlp_fmttype_cfgrd0);
*(rp_reg1) = tlp_cfg_dw1( ((0 << 8) | altrpcierp_devfn), tlp_read_tag);
*(rp_ctrl) = rp_tx_sop;
Any idea about accessing via avalon-mm to PCIe rootport registers?.
