NIOS II library
Hello all,
well, it´s a very newbie question, so sory.
I´m doing my first software for NIOS II and I noticed that even when I do a "hello world" program the compiler builds the software with all ANSI C libraries, but I´m not using the most of them. The problem is that it consumes a lot of memory. So, can I do something for the compiler to take only the libraries the current program uses?
Thanks a lot,
Vinícius.
I hope this puts you in the right direction. but it's not a complete answer.
Try optimising the code, like -O3??
Someone else can comment also. I think it's been discussed in another thread.
Hi vgarcia!!
Let's try this in NiosII IDE:
1) click right on "hello_world_syslib" project and click "Properties"
2) in "C/C++ Build" panel, set the "Optimization Level" to "Optimize most (-O3)" and define the following symbol for the "Preprocessor": ALT_NO_INSTRUCTION_EMULATION
3) in "System Library" panel, set "Periodic system timer" to "none"; set "Max file descriptor" to 4; uncheck "Clean exit"; check "Reduced device drivers"; check "Small C Library
4) click right on "hello_world" project and repeat step 2
5) build all and have fun! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif
Bye
