Hello all,
I am looking at an existing C code of NIOS II RTOS microC/OS-II. I see a bunch of OSTimeDly(1); being used in the code.
How do I determine how long is the time delay? is it 1 second or 1 microsecond or does it account to some other number? can you help?
thanks,
MK
Hi @MK_ABQ,
Thank you for posting in Intel community forum and hope all is well.
Per understand the actual time duration of delay task by 1 ticks which usually defined in the BSP.
Perhaps you can check if it being defined under the files os_cfg.h
Note: Usually OSTimeDly(1) means delay this task for 10 ms
Best Wishes
BB
Hi @MK_ABQ,
Best Wishes
BB
Hi @MK_ABQ,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
Hi @MK_ABQ,
Great! Good to know that your doubts has been clarified, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread. Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
