12723 Discussions
NIOS SDK tools don't see memory region
bob_bitchen
We use an Arrow LPDDR controller from the BeMicro designs back with Quartus 12.
I have a CIV E design in Quartus 21 lite with a NIOS II F.
In platform designer, the NIOS vector selection drop-down boxes have the selection for mddr_ctrl_0.avalon_slave, and appears to generate the system successfully along with the sopcinfo file appears to have all the necessary items.
The tcl file is from a previous version, but it does have "is_memory_device" set to true.
The bsp generation scripts show the following:
Executing: wsl nios2-bsp hal . ../../Aggs.sopcinfo --cpu-name nios2_gen2_0 (D:\Altera\Kits\PCIe-AGGS\software\bsp)
nios2-bsp: Using /mnt/d/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl to set system-dependent settings.
nios2-bsp: Creating new BSP because ./settings.bsp doesn't exist.
nios2-bsp: Running "nios2-bsp-create-settings.exe --sopc d:/Altera/Kits/PCIe-AGGS/Aggs.sopcinfo --type hal --settings ./settings.bsp --bsp-dir . --script d:/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl --cpu-name nios2_gen2_0"
INFO: Creating BSP settings file...
INFO: nios2-bsp-create-settings --sopc d:/Altera/Kits/PCIe-AGGS/Aggs.sopcinfo --type hal --settings ./settings.bsp --bsp-dir . --script d:/intelfpga_lite/21.1/nios2eds/sdk2/bin/bsp-set-defaults.tcl --cpu-name nios2_gen2_0
INFO: Initializing SOPC project local software IP
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/*</b> matched 112 files in 0.10 seconds
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/*/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: [Info] <b>D:/Altera/Kits/PCIe-AGGS/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: [Info] <b>D:/Altera/Kits/ip/**/*_sw.tcl</b> matched 0 files in 0.00 seconds
INFO: Finished initializing SOPC project local software IP. Total time taken = 2 seconds
INFO: Searching for BSP components with category: driver_element
INFO: Searching for BSP components with category: software_package_element
INFO: Found Flash Memory: epcs_flash_controller_0 for CPU: nios2_gen2_0
INFO: Loading drivers from ensemble report.
INFO: Finished loading drivers from ensemble report.
INFO: Tcl message: "STDIO character device is jtag_uart"
INFO: Tcl message: "System timer device is sys_clk_timer"
SEVERE: CPU "nios2_gen2_0" reset memory "mddr_ctrl_0" has no matching memory region.
WARNING: Tcl script "bsp-set-defaults.tcl " error: CPU "nios2_gen2_0" reset memory "mddr_ctrl_0" has no matching memory region.
SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry, .exceptions, .rodata, .rwdata, .text, .bss, .heap, .stack]"
SEVERE: nios2-bsp-create-settings failed.
nios2-bsp: nios2-bsp-create-settings.exe failed
I tried digging into the tcl files that print those messages, but I think the .exe is writing those errors.
Help!!
EBERLAZARE_I_Intel
Can you share the design I will try to replicate the issue.
bob_bitchen
I zipped the "software" although any create this bsp call will fail.
bob_bitchen
I don't find any info on changes to the tcl file for a NIOS tool compatible custom memory interface.
bob_bitchen
Bump
EBERLAZARE_I_Intel
Thanks for the file, I will look into it.
EBERLAZARE_I_Intel
I am still working on the case.
EBERLAZARE_I_Intel
From your side was your design compiled successfully in Quartus?
bob_bitchen
As far as I know, it's fully functional in hardware.
Have you looked at it yet?
bob_bitchen
It's time to decide if we can use these product or not
EBERLAZARE_I_Intel
I am having issues with the design you've sent, there are lots of errors from my side when using 21.1 Quartus.
For testing purposes, can you do a simple hello world build? Does that also produced the same error?
bob_bitchen
I have several projects that can't target my custom memory interface with the elf file.
It looks like the project archiver is pretty useless here.
How can zip the whole thing up and get it to you?
bob_bitchen
Here is a fully functional Quartus 11.1 project.
Convert this to whatever version that you wish, and you will find that the once-working NIOS tools have been recently broken.
bob_bitchen
This is what the NIOS tools look like when they work.
bob_bitchen
This is Quartus 21.1 lite results.
bob_bitchen
Even though the compiler / linker won't acknowledge any memory, the hardware can still test it. Q21.1 lite
EBERLAZARE_I_Intel
Thanks for the feedback and attached design, I will try to test that one out.
EBERLAZARE_I_Intel
I am seeing the same as your working output that you attached, I haven't seen the error in the BSP Editor problems from my side,.
My steps was getting your latest design, upgraded to 21.1 lite, then use the sopcinfo for Nios II EDS hello world example, all build are fine.
Could you retry the above and see if the fresh steps could be working or if it still reports error let me know.
bob_bitchen
Try using the mddr in the linker script. Or set it to the reset vector in the Nios.
bob_bitchen
The original title was "NIOS SDK tools don't see memory region"
So, I gave you a project that doesn't use the memory region because you couldn't get one to compile.
I fixed your problem for you, and now you are supposed to fix the original Intel bug that you introduced prior to Q21.
A month and a half, and you have made zero progress on this.
bob_bitchen
Bump
