NIOS2 22.1 version & SGDMA
syed6
Hi team,
we are upgrading the design from 13.1 to 22.1. In our design we have ethernet ip TSE, in 13.1 ethernet TSE is handled SGDMA while we generate the bsp the SGDMA files are generated, and application built without any issues. But in Quartus version 22.1 the same design is migrated and generated .sopcinfo file, while generating bsp the SGDMA files are missing whereas the mSGDMA files are generated. we are facing issues no SGDMA files are available.
Board we are using is Cyclone 5 - 5CGTFD9D5F27C7.
can you please give some information on this issue.
Thanks in advance.
JingyangTeh
Hi
The example for the Nios@ with SGDMA have been release a long time ago and there is no longer support for the example design.
I managed to find a more recent example design for the Nios2 with mSGMA for the quartus 18.1 and managed to upgrade it to the 22.1 version.
Could you try the example below:
https://community.intel.com/t5/FPGA-Wiki/MSGDMA-design-example/ta-p/735335
Jingyang, Teh
JingyangTeh
Hi
Any update on this case?
Jingyang, Teh
JingyangTeh
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang, Teh
