12710 Discussions
Nios® II EDS WSL and Ubuntu versions
ETang2
Hello, in the Intel® FPGA Software Installation and Licensing we need to install WSL 1 and Ubuntu 18.04 : https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/installing-windows-subsystem-for-linux.html
WSL 1 is old and Ubuntu 18.04 will no longer be supported in April 2023!
Do you know if this will be upgraded to support WSL 2 and at least Ubuntu 20.04 (22.04 ?)
Eric
EBERLAZARE_I_Intel
We currently have no support for Windows 11 yet, as it is still recommended to use Linux environment..
Regarding the support, you may refer to:
https://www.intel.com/programmable/technical-pdfs/726952.pdf#page=7
EBERLAZARE_I_Intel
As of today, we have no update regarding the future support to switch to WSL 2 nor Ubuntu 20.04.
We do recommend users to use Linux environment for better future experience.
ETang2
Hi, thank you for the answer.
Another solution could be to use NIOS V instead of NIOS II. Could NIOS V be implemented on DE10-Lite card ?
LFrin
Hi, did you try wsl version 1 with Ubuntu 20.04 lts? The Nios II EDS runs fine at my machine with this Ubuntu version.  I think the new Nios V is only supported by the Quartus Prime Pro version.
ETang2
Hi, no i did not try. I will test but i use win11 + wsl version 2 ...
About NIOS V, you are right it is only supported by the pro version which is not available for MAX10.
EBERLAZARE_I_Intel
I am checking the info with our internal team, I shall let you know once we have them.
EBERLAZARE_I_Intel
