12612 Discussions
Nios II : USB/Blaster not found (windows 8)
I want use Nios II but my De0-nano is not found (USB/Blaster)
- I have Windows 8.1
- The USB-Blaster is found on system (peripherals)
- I have the USB-Blaster on Quartus 13.0
- I have a SD reader then I desactived it
Thanks for your help
Jennifer
ps; i will try to use the 15.0 version, may be !!!!
maybe you could try with the half cooked solution from here:-
http://altera-guide.blogspot.my/
--- Quote Start ---
ops.... i did not see windows 8 in this page,
https://www.altera.com/support/support-resources/download/drivers/usb-blaster/dri-usb-blaster-vista.html
--- Quote End ---
Windows 8 works fine with the instruction in the link for my case though =D
better go to file a case and ask Altera to update this instruction to support win8 then! :D
