U-Boot is a boot monitor that supports a variety of processors including: Nios-II, Nios-32, PowerPC, ARM, MIPS, and x86. It is licensed under the terms of the GPL.
A patch has (just) been submitted to the u-boot project that includes support for Nios-II processors. Hopefully, the patch will be added to the main source tree within the next few weeks. See http://www.sourceforge.net/projects/u-boot (http://www.sourceforge.net/projects/u-boot) for more information. See below for the initial features. Source code and pre-built binary/srec files for Nios-II Cyclone Development kit are now available at: http://www.psyent.com/download (http://www.psyent.com/download) Regards, --Scott ===================================================================== Nios-II U-Boot Features ===================================================================== -Serial or JTAG console -Flash memory programming support -Networking support -DHCP -BOOTP/TFTP -NFS client -ping -File download support -TFTP -NFS -Kermit (serial port) -S-Record (serial port) -Environment/Scripting support - ... and moreLink Copied
Hi Scott.
Do you know by chance, if the U-Boot can support TFTP on "standard32" hardware image, for the Nios32 cyclone development kit?- Mark as New
The "do_bootm_linux" is not completed. Is that not the one that should be used for starting the system???
Correct. It is not implemented yet. >Is that not the one that should be used for starting the system??? For starting the operating system, yes. Depending on your linux init code, you may be able to start linux with the "go" command until do_bootm_linux() is implemented -- or you could implement the routine yourself and submit a patch :-) --Scott- Mark as New
Yes, TFTP is supported for Nios-32.
I have successfully used tftpboot, bootp, ping, etc. using the "standard-32" configuration on the DK-1C20 (Altera) development board. Regards, --Scott- Mark as New
I would like to know if u-boot could work on a Stratix board? Christian- Mark as New
Yes, for Nios-32 support you can use the DK1S10 configuration. For Nios-II you _may_ be able to use the PK1C20 configuration without any modifications -- give it a try. If the PK1C20 configuration doesn't work, the easiest thing to do (until a stratix config is developed) is: 1. Get the source code. 2. Edit include/configs/PK1C20.h -- change macros as appropriate. 3. Build u-boot: $ make distclean $ make PK1C20_config $ make Then use u-boot.srec, u-boot (elf) or u-boot.bin (binary) as you see fit. BTW: the binary can be stored at an arbitrary address (e.g. flash) as it will relocate itself into SDRAM. Regards, --Scott- Mark as New
The bootm command is now implemented. This lets you
boot or run kernels, scripts, etc. It fully supports gzip and bz2 decompression (for compressed kernels). In order to use bootm you will need to use the u-boot 'mkimage' utility. mkimage is used to create the u-boot image files. mkimage and updated binary/source archives are available at: http://www.psyent.com/download (http://www.psyent.com/download) I tested by booting a gzipped Microtronix linux kernel on the Altera 1C20 devkit board. Result were pretty good: vmlinux.bin: 1.6 MB (original binary) vmlinux.img: 678 KB (gzipped u-boot image). BTW: see the README in the mkimage zip file for instructions. Regards, --Scott- Mark as New
I tried this on Altera Stratix 1s40, it works with flying colors. Thanks Scott.
