i have to install uclinux for nios ii processor.
where do i install uclinux, should it be installed in linux or in windows operating system?
currently,i have both ubuntu(karmic version) as linux operating system and windows operating system
altera quartus ii 7.0 and nios ii ide have been installed in windows operating system.
Please tell me the procedure to install uClinux-on either Linux (Ubuntu) or Windows OS ?
The procedure for using uCLinux with NIOS can be found on here (http://www.nioswiki.com/operatingsystems/uclinux).
I am trying to boot with uClinux and tried the following http://nioswiki.com/linux/linux_quick_start, but as you see I encountered a problem. ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-configure-sof /home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof /opt/altera10.0sp1/quartus/adm/qenv.sh: line 109: warning: setlocale: LC_CTYPE: cannot change locale (en_US): No such file or directory Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag -o p;/home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof Info: Using programming cable "USB-Blaster [USB 7-1.1]" Info: Using programming file /home/user/Altera/kits/cycloneIII_3c25_niosII/examples/standard_cd/cycloneIII_3c25_niosII_standard.sof with checksum 0x006ED7F9 for device EP3C25F324@1 Info: Started Programmer operation at Wed Sep 15 16:57:36 2010 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020F30DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Wed Sep 15 16:57:37 2010 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 77 megabytes Info: Processing ended: Wed Sep 15 16:57:37 2010 Info: Elapsed time: 00:00:04 Info: Total CPU time (on all processors): 00:00:00 ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-download -g images/linux.initramfs.gz Using cable "USB-Blaster [USB 7-1.1]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 5283KB in 46.7s (113.1KB/s) Verified OK Starting processor at address 0xD0000000 ~/nios2-linux/uClinux-dist [NiosII EDS]$ nios2-terminal nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 7-1.1]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) What did I do wrong? I checkout-ed and update-d my uClinux-dist before make and in which I press ENTER for (NEW).
