Hi all,
I am looking for support on Nios V executing on external memory.
This is a customer board with C10 GX.
The EMIF has been verified using the EMIF toolkit and the calibration report is fine.
I followed the steps to have the Nios V booting from GSFI, execute from onchip_ram and it's fine.
Now I change the settings of Linker Section Mapping to EMIF,
Then it's not working anymore.
Nios Vm connects to EMIF through an Avalon MM clock crossing bridge.
And the Quartus version is Pro. 24.1.0
Any suggestions or comments?
Thank you.
Hi
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Jingyang, Teh
Hi
For booting from EMIF. It is a little bit different from OnChip Memory.
In the OnChip memory you will initialize the OnChip Memory with the application hex and the NiosV processor do not need to transfer the application from another location.
For booting in the EMIF you could use the steps listed here:
You just need to follow the instruction replacing the RAM with your EMIF.
Jingyang, Teh
Hi
Do you have an update on this case?
Jingyang, Teh
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
