12748 Discussions
Nios flash-programmer utilities on linux
Hey all,
I need to include the elf2flash and sof2flash utilites in my buildroot scripts in Linux. Has anyone been able to get these working in Linux?
Tony
--- Quote Start ---
originally posted by arios01@Dec 5 2006, 11:08 AM
hey all,
  i need to include the elf2flash and sof2flash utilites in my buildroot scripts in linux.  has anyone been able to get these working in linux?
thanks,
tony
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19836)
--- quote end ---
--- Quote End ---
Yes, what are the specific problems you are seeing? Also, what version of the tools are you attempting to use?
- slacker
--- Quote Start ---
originally posted by slacker+dec 6 2006, 12:06 am--><div class='quotetop'>quote (slacker @ dec 6 2006, 12:06 am)</div>
--- quote start ---
<!--quotebegin-arios01@Dec 5 2006, 11:08 AM
hey all,
thanks,
tony
--- quote end ---
--- Quote End ---
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19844)</div>
[/b]
--- Quote End ---
There is no problem with the tools themselves. Up to now, I have been building my linux kernel in linux using the buildroot system and then using the NIOS IDE shell in windows to convert and flash the sof, kernel, and filesystem to the EPCS flash chip. This works great.
However, now I am trying to automate the process a little more by adding the creation of the EPCS flash file together with the creation of the kernel image in Linux. My end goal is to type &#39;make&#39; at the root of a fresh buildroot and kernel directory and have the buildroot system build the kernel from sources then create a single flash image that includes the sof, kernel, and filesystem to be loaded to the EPCS device.
At the moment, my make scripts can build a full kernel from fresh sources with a single &#39;make&#39; command. Now I just need to add the elf2flash tool to convert the elf vmlinux image to a flash image and run the sof2flash to convert the sof file to a flash image.
If I could do these in Linux, I can add it to my Makefile.
Tony
