12692 Discussions
Nios2-Linux incompatible with v9.0 generated ptf file
I have just recently discovered that Nios2-Linux is incompatible with v9.0 generated ptf files.
When I run the "make vendor_hwselect SYSPTF=my_ptf_file" command, it works with no errors. But when I compile with the "make" command, it gives the following errors :
sets.c:12: /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if /home/zero/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: division by zero in# if make: *** Error 1 make: *** Error 2 make: *** Error 2 make: Leaving directory `/home/zero/nios2-linux/linux-2.6' make: *** Error 1
It works fine with v8.1 ptf files.
as far as I remember, the warning
--- Quote Start ---
--- Quote End ---
means that your system.ptf is missing a full-featured timer
Hey thanks! It works now. I can confirm v9.0 works in Nios2-Linux.
Ill update the wiki when I have time.
