Old SDRAM burst problem
Hi all.
I want to make very fast data transfer from one SDRAM to another SDRAM
I make project with 2 sdram controllers and SW code Stack and DATA is in separate third SDRAM.
Need to make tranfer from x32 sdram to x16 sdram
But in burst mode with undefinded length
I use DMA and in timing diagramm i can see that transfer flow like
2 words - delay- 4 words - delay ..... and so on
I think that to solve this problem need big read buffer in DMA where DMA will read with burst mode of Source SDRAM and write from it in Burst Mode to destination SDRAM
I was trying to use Burst length option and in this case after i run DMA transaction - DMA go to Busy state for all time. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
And in documentation i did&#39;t find anything al all about burst length option of DMA controller.
So how to solve this ?
The existing SDRAM controller is not built for performance. Trying to squeeze performance out of it will be difficult. My advice would be to design your own or go purchase another SDRAM controller IP.
Cheers,
- slacker
