Open source OS
I am a beginner to embedded OS. can you introduce open source RTOS OS to work on Nios II ? I search for a free RTOS OS that its performance is similar to commercial OS such as ecos.
Best Regards.
Given that you are a beginner, it would be useful to read about an RTOS and be able to use the code. I would recommend downloading the Micrium books about uCOS-III.
http://micrium.com/
You may need to register to download the PDFs, but its definitely worth it.
The NIOS II examples already have uCOS-II examples.
If you want to understand how to port the OS, then read through this document (its for an ARM microcontroller);
https://www.ovro.caltech.edu/~dwh/ucos/project_ar1803.pdf
https://www.ovro.caltech.edu/~dwh/ucos/gcc_and_ucosii.zip
uCOS-II and uCOS-III are not open-source, but their source code is available to read. You can use the OS for university and non-commercial purposes.
Once you understand uCOS-II/III you can take a look at other OSes, eg., FreeRTOS.
http://www.freertos.org/
Cheers,
Dave
Dear Dave,
many thanks. I read some documents about RTOS previously. what is your opinion about read ecos documents to start RTOS learning?
I am an student and i am working on my final university project. How can i get license of uC/OS-III or uC/OS-II ?
Best Regards.
--- Quote Start ---
--- Quote End ---
I never found eCOS documentation particularly good. I have this book
http://www.amazon.com/embedded-software-development-anthony-massa/dp/0130354732
which you can download in PDF from
http://ecos.sourceware.org/docs.html
I read it, but was never inspired to use eCOS ... whereas I have had uCOS-II running in one system continuously since 2000.
--- Quote Start ---
--- Quote End ---
You don't need it. You already have the source to uCOS-II in your Quartus/NIOS installation. You can download the source to uCOS-III from the Micrium site, along with PDF copies of all the books they sell.
Cheers,
Dave
