PCI express and NIOS
I had a NIOS system working with my custom peripheral this morning on the transceiver starter kit this morning.
I then added a PCI express interface and had to modify the design a bit so I could fit it.
I then recompiled the NIOS and got....
undefined reference to `alt_ic_isr_register'
I see that# define ALT_ENHANCED_INTERRUPT_API_PRESENT is missing from the system.h file for some reason.
Any ideas?
Discovered problem.
It was my fault not really intuitive though.
When I removed the JTAG UART from Qsys and regenerated .sopcinfo
I got the error from eclipse
Of course the JTAG UART qsys inclusion was generating
In the system.h file.
My custom peripheral has no HAL driver and therefore no# _sw.tcl file to indicate enhanced interrupt API and therefore I needed to use legacy interrupts.
What I did was use conditional compilation i.e.
# ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
static void codec_isr (void *context)
# else
static void codec_isr(void *context, alt_u32 id)
# endif
And
a = alt_ic_isr_register (CODEC_BURST_MASTER_0_IRQ_INTERRUPT_CONTROLLER_ID ,CODEC_BURST_MASTER_0_IRQ, codec_isr, NULL, 0x0);
# else
a = alt_irq_register (CODEC_BURST_MASTER_0_IRQ_INTERRUPT_CONTROLLER_ID ,NULL, codec_isr);
# endif
And of course, using the legacy interrupts, the code now builds.
Let’s see if that will work.
