Problem with DS-5 Debugger
I just started on DS-5 using Arrow Cyclone V FPGASoC kit, and has a problem with the debugger.
According to "Altera SoC Embedded Design Suite User Guide", when I open Debug Configuration, I should see Altera Cyclone V A9 processor related information, as listed in the picture in attachment.
However, my has nothing related to Altera or any processor, also listed in attached pictures.
I strictly follow the instructions. I appreciate any help on this~~
Thanks~~
did you open up any example design project...?
I created a hello world project first following the instructions of "Altera SoC Embedded Design Suite User Guide". Any difference with example project?
oh. no, just trying to isolate if this is some EDS setup issue, as the example is working version. by the way, had installed your usb blaster as well?
Yes, USB-Blaster installed. I will try design example tonight.
Tried example project, the same problem.
USB Blaster installed, following instructions strictly......
solved, I use DS-5 community version, actually datasheet is talking about Altera Edition...
like i said in another post of yours.... this community edition license is just for leisure purpose... not suitable for developer like you.
