12747 Discussions
Problem with NIOS II embedded Linux installation
I installed the Nios II embedded linux with Nios 1.1 and quartus II 4.2, but I could not find the "Configure Kernel" command in the drop-down menu when I tried to build a linux kernel project. The Quartus II 4.2 was installed by another engineer who installed it under c:\quartus\ instead of using the defauld installation directory c:\altera\quartus42\. I don't know if it is a matter for the installation of the linux or there is anything else caused the problem.
Olive
OK, it is in the Navigator window. The C/C++ window is so similiar to the Navigator window that I did not relized I was in the wrong window to configure the kernel.
-Olive
