Problem with NIOS
I don't know operation
Ex:
Kiem_tra_N_va_Xuat_LED:
call CheckN1
call CheckN2
call CheckN3
call Check3N
call OutLED
br -44
Why br -44 ?????
Thank you everyone. Thank you very much
You might need to give a little more context!
Also enclose program text inside 'CODE' tags (# on 'advanded' window) to keep indentation.
I'd guess that is a bit of assembler listing output?
'br -44' is an unconditional jump, offset is from the following instruction.
--- Quote Start ---
--- Quote End ---
Why "-44"? Why don't we use "-48","-40" or "40", "48"
Thank you!
Everyone, help me!I do exercise
Because that is where in needs to jump to.
