Problem with ecos2.0 release
I downloaded latest eCos release for NIOS1.1.I installed quartus4.2 and NIOS1.1 on my system to build eCos2.0.
When I gave command
nios2configtool --ptf=std_1s10.ptf --cpu=nios2
it resulted into errors as mentioned below.
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGHWR_HAL_SYSCLK_DEV, property legal_values: error
End of expression reached when expecting an operand.
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGHWR_HAL_NIOS2_TEXT_REGION, property legal_values: error
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGHWR_HAL_NIOS2_RODATA_REGION, property legal_values: error
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGHWR_HAL_NIOS2_RWDATA_REGION, property legal_values: error
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGSEM_ROM_MONITOR_TEXT_REGION, property legal_values: error
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGSEM_ROM_MONITOR_RODATA_REGION, property legal_values: error
<end of data>{ ...}
c:/DOCUME~1/ADMINI~1.WIN/LOCALS~1/Temp/nios2_auto.cdl, option CYGSEM_ROM_MONITOR_RWDATA_REGION, property legal_values: error
<end of data>{ ...}
I checked nios2_auto.cdl file which is generated automatically. It is like,
cdl_option CYGHWR_HAL_NIOS2_TEXT_REGION {
display "text region"
parent CYGPKG_HAL_NIOS2
flavor data
legal_values { }
default_value { CYG_HAL_STARTUP == "ROM" ? "UNDEFINED VARIABLE %LARGEST_ROM_MODULE%" : "UNDEFINED VARIABLE %
LARGEST_RAM_MODULE%" }
description "
This option allows you to define the memory region used for the
text section. The names of the available memory regions are the names
assigned in SOPC builder."
There is nothing specified in legal_values option which is causing problem. This problem is same for all of the above mentioned errors. Can anybody help me with this problem.
Thanks and Regards,
Firstly a quick note on version numbers, since this may cause confusion. eCos 2.0 was released for Nios II 1.0 service pack 1. The version of ecos that has been subsequently released for Nios II 1.1 incorporates a number of bug fixes and enhancments from the public eCos CVS repository. It is therefore not eCos 2.0. It hasn&#39;t been assigned an official release number by the eCos community, and so I refer to it simply as "eCos for Nios II 1.1".
I hope that&#39;s the version you are trying to run.
In any case, I&#39;m guessing that you have assigned the wrong cpu name. The value passed to the --cpu option for nios2configtool is the name assigned to the processor in SOPC builder, rather than the type of processor. In all the Altera example designs the name is simply "cpu", so the command line you were looking for was probably:
nios2configtool --ptf=std_1s10.ptf --cpu=cpu
