Problem with first run
This is a newbie question.
Installation and upload of the kernel and file system went smoothly on my 1s10 development board. Howerever first connection via terminal with the uClinux failed with the following message: Warning: unable to open an initial console although LED/7seg. counter did run. I will appreciate if anybody could help me. The configuration of my system and full listing of the terminal window are:
- Quartus 4.1 SP2
- Nios II
- ByteBlaster JTAG UART
- free RJ1 Ethernet socket
- no CompactFlash card on the socket
Listing:
[SOPC Builder]$ nios2-terminal
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios
nios2-terminal: II systems. You may experience intermittent JTAG communication
nios2-terminal: failures with this cable. Please use a USB Blaster revision B
nios2-terminal: cable or another supported cable. Please refer to the file
nios2-terminal: errata.txt included in the Nios II development kit documents
nios2-terminal: directory for more information.
nios2-terminal: starting in terminal mode only (Control-C exits)
Linux version 2.6.5-uc0 (placki@placki-mobl) (gcc version 3.3.3 (Altera Nios II
1.0 b316))# 1 Fri Nov 26 15:39:05 CEST 2004
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
On node 0 totalpages: 4096
DMA zone: 0 pages, LIFO batch:1
Normal zone: 4096 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 16 (order 4: 128 bytes)
Memory available: 14512k/4096k RAM, 0k/0k ROM (1365k kernel code, 303k data)
Calibrating delay loop... 37.27 BogoMIPS
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
POSIX conformance testing by UNIFIX
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.3 $
ttyJ0 at MMIO 0x80920820 (irq = 1) is a jtag_uart
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 75000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x80910300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:
ed:0a:a7:fd
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=1
hda: 3SYSTEM SSSCF016MAA, CFA DISK drive
Using anticipatory io scheduler
ide0 at 0x80920900-0x80920907,0x80920938 on irq 5
hda: max request size: 128KiB
hda: 31744 sectors (16 MB) w/2KiB Cache, CHS=248/4/32
hda: hda1
microtronix[mtd]: RAM probe address=0x200000 size=0x1ec000
Creating 1 MTD partitions on "RAM":
0x00000000-0x001ec000 : "ROMfs"
microtronix[mtd]: set ROMfs to be root filesystem
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
NET: Registered protocol family 17
VFS: Mounted root (romfs filesystem) readonly.
Freeing unused kernel memory: 48k freed (0x1186000 - 0x1191000)
Warning: unable to open an initial console.
Piotr.
Sounds like its possibly a problem with the console device node.
In the filesystem project that you have, can you double check that there's a file called:
<project>/target/dev/@console,c,5,1
If the file doesn&#39;t exist, try creating a blank file with the name I just provided. Re-build, and re-upload your filesystm project as detailed in the Getting Started Guide.
I&#39;m about to leave for the weekend but I&#39;ll be back on Monday morning if my advice above didn&#39;t work.
Thaks for your help.
This is weird but I didn&#39;t have /dev/ subdirectory under my filesystem project at all...
oh... hmm... if you build a new filesystem project, does it include the /dev directory? I believe you need to enable the "base" package when configuring the filesystem project through the "new project wizard".
Yes, but the weird thing is that I did it. Second attempt to build a new filesystem from the scratch was OK. Anyway thanks for your help again.
Piotr.
TO_BE_DONE
Looking at the kernel commandline, I noticed that you passed:
root=/dev/hda rw
/dev/hda represents the entire disk/drive. What you want is to specify a partition. In your case, that would be the first partition.
So your kernel command line should read:
root=/dev/hda1 rw
Give that a try... I think that should solve the problem.
--- Quote Start ---
originally posted by ken@Nov 30 2004, 11:12 AM
looking at the kernel commandline, i noticed that you passed:
root=/dev/hda rw
/dev/hda represents the entire disk/drive.  what you want is to specify a partition.  in your case, that would be the first partition.
so your kernel command line should read:
root=/dev/hda1 rw
give that a try... i think that should solve the problem.
--- Quote End ---
another error:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Built 1 zonelists
Kernel command line: root=/dev/hda1 rw
Memory available: 14480k/4096k RAM, 0k/0k ROM (1394k kernel code, 306k data)
Calibrating delay loop... 24.78 BogoMIPS
smc_probe: 50000 Khz Nios
ed:00:00:00
CF: ctl=1
hda: CF 16MB, CFA DISK drive
hdb: no response (status = 0xff), resetting drive
ide0 at 0x80900800-0x80900807,0x80900838 on irq 8
hda: 31232 sectors (15 MB) w/1KiB Cache, CHS=61/16/32
hda: hda1
microtronix[mtd]: RAM probe address=0x200000 size=0x538000
0x00000000-0x00538000 : "ROMfs"
hda: hda1
hda: hda1
hda: hda1
Kernel panic: VFS: Unable to mount root fs on hda1[/b]
--- Quote End ---
the cf is formatted with ext2fs.hda1 has bootable primary partition,as the quick guide suggest.
what is the way? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
another problem now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
--- Quote Start ---
uClinux/Nios II
Built 1 zonelists
Memory available: 14788k/4096k RAM, 0k/0k ROM (1134k kernel code, 259k data)
Calibrating delay loop... 24.72 BogoMIPS
ed:ff:8c:ab
CF: ctl=1
VFS: Cannot open root device "hda1" or unknown-block(0,0)
Please append a correct "root=" boot option
Kernel panic: VFS: Unable to mount root fs on unknown-block(0,0)[/b]
--- Quote End ---
what is that? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
we also have tryed with the correct device minor-major number(hda is 0301,as the file on /dev indicate)
no boot,the bios cannot found the device(unknown block(3,1) )
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
hey,nobody can help me? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
