Problem with reset NIOS
Dear everybody,
I design an external watchdog that activate the resetRequest signal when the NIOS does not respond within a certain time.
When I caused theAVALON bus to crash, the resetReuest signal is active but the NIOS not active resetTaken signal.
If I reboot the NIOS using a reset_n, the NIOS not init.
How I can reset the NIOS?
Best Regards
