12748 Discussions
Problems with compiling FreeRTOS
Hi!
I'm new to NIOSII and embeded processors. I have some problems with compiling FreeRTOS.
In port.c file compiler shows following warnings:
assignment from incompatible pointer type port.c test2/Source/portable/GCC/NiosII 220 implicit declaration of function `alt_irq_disable' port.c test2/Source/portable/GCC/NiosII 223 implicit declaration of function `alt_irq_enable' port.c test2/Source/portable/GCC/NiosII 223 implicit declaration of function `alt_irq_register' port.c test2/Source/portable/GCC/NiosII 165 linker shows following errors:
undefined reference to `alt_irq_disable' port.c test2/Source/portable/GCC/NiosII 223 undefined reference to `alt_irq_enable' port.c test2/Source/portable/GCC/NiosII 223 C/C++ Problem undefined reference to `restore_sp_from_pxCurrentTCB' port.c test2/Source/portable/GCC/NiosII 143 C/C++ Problem Any advice?
I found solution on FreeRTOS page. I had to install a new version of port.c file for NIOS EDS 9.1 and higher.
hi, has anyone succeeded in compiling a project with freertos under nios ii eds 12.0 (sp1) ?
I have tried to compile demo projects without success. The template disappears (it is magic :-)) form the drop down menu when creating new project.
I have also tried to include FreeRTOS by the Eclipse configuration but no success (too many unresolved# include that is fastidious to .... resolve by fixing paths)
Does anyone have a good way to include FreeRTOS in a Nios II EDS project ?
