Programming problems
I have an altera cyclone (1c20) Nios-II dev board, and am attempting to get uclinux up and running. However, I'm running into an odd problem when trying to upload...
I always get either
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Microtronix Linux Extensions
Version 1.3, Built December 30th, 2004
Feb 20, 2005 9:09:37 PM - (INFO) nios2-flash-programmer: Launching Quartus Progr
ammer to download:
  c:/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20/system/a
ltera_nios_dev_board_cyclone_1c20.sof
Pre-Reading 1726KBytes of data from U5:
    ******Read failed @00080000
Feb 20, 2005 9:10:20 PM - (SEVERE) nios2-flash-programmer: Error copying data to
the flash target[/b]
--- Quote End ---
The progress bar and "Read failed" address are inconsistent, but I have yet to get past this step.
OR I get something along the lines of...
--- Quote Start ---
Feb 20, 2005 9:04:09 PM - (INFO) nios2-flash-programmer: Launching Quartus Progr
ammer to download:
Feb 20, 2005 9:04:19 PM - (SEVERE) nios2-flash-programmer: Error opening target
hardware
Failed to get header for variable-payload packet.
Feb 20, 2005 9:04:19 PM - (SEVERE) nios2-flash-programmer:    Unable to open fla
sh-device after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which
was not created for your target board.
  In order to program flash, you must first create a purpose-built
  flash-programming design (i.e. FPGA configuration) and associate it with
  your particular board.  The Nios development kit is delivered with purpose-bui
lt
  flash-programming designs pre-built for several development boards.  If you wi
sh
  to program flash on your own board, you must first create a flash-programming
  design.
  The process of creating a flash-programming design for your board is mostly
  automated.  From a bash-shell, execute this script:
        mk_target_board --help
  The help-message includes references to other documentation on programming
  flash and targeting Nios systems to custom board designs.
- exiting.[/b]
--- Quote End ---
With inconsistant "SEVERE" messages, but generally along the lines of what&#39;s above.
The odd thing is that I can program this .sof just fine using the Quartus programmer, and, unfortunatly, when I do so, nios2-flash-programmer attempts to reprogram it.
Any thoughts? Could this be a hardware issue? Any help would be greatly appreciated, as I&#39;m at a bit of a loss at this point.
--Nate
After several hours of repetedly attempting to flash various files different ways, finally some progress, but still not quite there.
--- Quote Start ---
Feb 21, 2005 12:59:31 AM - (INFO) nios2-flash-programmer: Launching Quartus Prog
rammer to download:
    ********************* (18.813 sec).
Erasing 27 Sectors:
    ********************* (31.703 sec).
Writing 1728KBytes :
    *Unable to send write-packet @49152
buffer-chunk write failed @49152
erase-block write failed @49152
write failed @0
Feb 21, 2005 1:00:37 AM - (SEVERE) nios2-flash-programmer: Unable to write to fl
ash
Feb 21, 2005 1:00:37 AM - (SEVERE) nios2-flash-programmer: Error: Write-operatio
n failed on device. - exiting.[/b]
--- Quote End ---
I&#39;m starting to suspect a bad usb-blaster, but I could be wrong.
--Nate
I&#39;ve also encountered the:
Feb 20, 2005 9:04:19 PM - (SEVERE) nios2-flash-programmer: Unable to open flash-device after successfully communicating with target.
error. This problem went away after I upgraded to Quartus 4.2
Hope this helps.
Terry G.
