All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
12577 Discussions
Replace the GHRD SD MMC to be a smaller EMMC chip?
Hi, Any precaution for us to replace the current SD MMC slot to another eMMC slot? is the communication is compatible all the way?
if read from the hand book bot protocol looks compatible....
Yes, eMMC this is a compatible protocol with SD MMC,
take note that when follow the golden reference, the SD MMC configuration is in 4 bit data, where not fully utilize all the 8 bit data mode...
how is the physical connection? it is compatible between emmc and sd card?
yes... that's right... it is compatible.
Hey the boot time of the soc guide for sd cars is using the golden design? That is not with maximum 8 bit data. Only 4 bit. Could it becomes even shorter boot with 8 bit?
definitely yes...with maximum supported data width.
there fore you are good to use any emmc type as long as supported by the controller
