12686 Discussions
Restoring archived Nios II Application & BSP project
Hi there,
I have an archived Nios II project, which includes the following files:
Application Project directory:
.c/.h source code & headers
.project
.cdtproject
.cdtbuild
application.stf
BSP Project directory:
.project
.cdtproject
.cdtbuild
system.stf
As stated in Appendix A of the Nios II Software Developers Handbook, this should be all that is required to reconstruct my BSP & ELF files. The question is "how?" In the Nios II IDE (10.0sp1) I can't find a method to reopen or import these project files without creating a new project and overwriting the existing files. This lead to some BSP configuration issues as you can imagine.
Thanks!
Jason
A follow-on question: are these files specific to the Nios II IDE and if so, can they be imported directly to the Nios II SBT?
Problem solved.
These files are specifically for the Nios2 IDE, not to be confused with the Nios2 Eclipse plugin (a.k.a. Nios II Software Build Tools for Eclipse). After importing the App and BSP directories into the IDE, and selecting the correct .ptf file, I could build the program without trouble.
Once built for Debug or Release, I used the nios2-convert-ide2sbt command and rebuilt the project in SBT.
