12681 Discussions
SDRAM controller Timing parameters
homeinit
Could anyone help me to understand these parameters:
I want to add my memory but I am struggling a little bit with the timing since the datasheet has not had the same naming.
I am using the H57V2562GTR-75C running at 133MHz.
Thank you  in advance
homeinit
Hello, I managed to solve my issue, here are my values, it works for the moment, and the code is running from the SDRAM:
[crt0.S] Inst & Data Cache Initialized.
[crt0.S] Setting up stack and global pointers.
[crt0.S] Clearing BSS
[crt0.S] Calling alt_main.
[alt_main.c] Entering alt_main, calling alt_irq_init.
[alt_main.c] Done alt_irq_init, calling alt_os_init.
[alt_main.c] Done OS Init, calling alt_sem_create.
[alt_main.c] Calling alt_sys_init.
[alt_main.c] Done alt_sys_init.
[alt_main.c] Calling main.
Hello from Nios II!
I am running the code from the SDRAM and I wondering why I have [xxx] xxx messages before the program? if you have an idea/explanation I'll take it!
Thank you!
RichardTanSY_Intel
You may checkout this page on the parameters description.
https://www.intel.com/content/www/us/en/docs/programmable/683130/21-4/timing-page-30722.html
Unfortunately, I am not familiar with the device H57V2562GTR-75C so I can't advice much on that.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
homeinit
Hello from Nios II!
Thank you!
RichardTanSY_Intel
I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
Richard Tan
