12690 Discussions
SGDMA descriptor list questions
I want to build a descriptor linked list to transfer data form memory to TSE MAC.If I build one descriptor there's no problem.If I build more than one descriptors no data was transfered.Is there anybody tell me why?
this is the code:
alt_avalon_sgdma_register_callback(pM_Context->mac_mi.tx_sgdma,
&sgdma_transmit_callback_function,
( ALTERA_AVALON_SGDMA_CONTROL_IE_GLOBAL_MSK |ALTERA_AVALON_SGDMA_CONTROL_IE_CHAIN_COMPLETED_MSK)
pM_Context);
for(i=0;i<ASYNC_TRANS_DESC_MAX;i++)//||
printf("config descrip \n");
p_write = pM_Context->Frame_List.Pbuffer[pM_Context->Frame_List.rear]+pM_Context->Frame_List.offset;
pM_Context->Frame_List.offset += pM_Context->Frame_List.packetsize;
pM_Context->Frame_List.framesubnum++;
//packet_length = pM_Context->Frame_List.packetsize;
alt_avalon_sgdma_construct_mem_to_stream_desc(&pM_Context->Current_desc[i], // descriptor
&pM_Context->Current_desc[i+1], // next descriptor
(alt_u32 *)p_write, // read buffer location
(pM_Context->Frame_List.packetsize), // length of the buffer
0, // reads are not from a fixed location
1, // start of packet is enabled for the Avalon-ST interfaces
1, // end of packet is enabled for the Avalon-ST interfaces,
0); // there is only one channel
alt_avalon_sgdma_do_async_transfer(pM_Context->mac_mi.tx_sgdma,
pM_Context->Current_desc);
for(tse_ptr->chain_loop = 0; tse_ptr->chain_loop < ALTERA_TSE_SGDMA_RX_DESC_CHAIN_SIZE; tse_ptr->chain_loop++)
tse_ptr->pkt_array[tse_ptr->chain_loop] = pk_alloc(ALTERA_TSE_PKT_INIT_LEN+4);
if (!tse_ptr->pkt_array[tse_ptr->chain_loop]) /* couldn't get a free buffer for rx */
dprintf("[tse_sgdma_read_init] Fatal error: No free packet buffers for RX\n");
tse_ptr->netp->n_mib->ifInDiscards++;
return ENP_NOBUFFER;
// ensure bit-31 of tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff is clear before passing
// to SGDMA Driver
uncached_packet_payload = (alt_u32 *)alt_remap_cached ((volatile void*) tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff, 4);
alt_avalon_sgdma_construct_stream_to_mem_desc(
(alt_sgdma_descriptor *) &tse_ptr->desc[tse_ptr->chain_loop+ALTERA_TSE_FIRST_RX_SGDMA_DESC_OFST], // descriptor I want to work with
(alt_sgdma_descriptor *) &tse_ptr->desc[tse_ptr->chain_loop+ALTERA_TSE_SECOND_RX_SGDMA_DESC_OFST], // pointer to "next"
uncached_packet_payload, // tse_ptr->pkt_array[tse_ptr->chain_loop]->nb_buff, // starting write_address
0, // read until EOP
0); // don't write to constant address
I find the code in the TSE MAC IP.
I'm trying the same thing... have you come to a solution?
