12693 Discussions
TCP stack broken in nios2-linux-20100621.tar
Hi All,
I made an image based on nios2-linux-20100621.tar and loaded it on a cyclone III dev board. the linux and filesystem are working OK. I managed to ping the nios successfully. Problems started when trying to ssh it.
The ssh client on PC is stuck waiting for a reply from the sshd on the nios. running TCPdump on the nios show that it get the SYN packet but issue no ACK back. It seems like a basic TCP issue not related to the server listening to the socket.
Any idea? btw, I couldn't connect to the git server on 140.118.20.145 (in ./update) there seem to be no server listening on that ip..
Lior
The tar file is quite old and supposedly needs a lot of git updates to be workable.
If you are locked in behind a firewall you need to access git via http. Did you try this ?
-Michael
I'm trying it now. it takes ages...
thanks, I'll let the forum knows how it goes...
Lior
Yep. It's known that gut via http is slow.
-Michael
ok. after updating to trunk it seems to work fine...
thanks
Lior
