THE WM8731 ON DE2
THE WM8731 ON DE2
serial data from digital audio interface
I want to make "serial data", which is out of digital audio interface after AD sampling in WM8731,into the 16bit "parallel data",which will be stored in the SRAM on theED2 board.
So I want to ask what should I do? Are there some module programme available?
Some days ago, I have write a verilog programme for serial-to-parallel conversion.But, the result of function simulation is not correct.
ps:1.AD sampling rate is 8KHZ
2.ADCDAT is 16 bit
3.NORMAL mode
4.digital audio interface format is I2S.
5.programme I have write as follow:
//when AUD_ADCLRC==0, do 16bit serial-to-parallel.this module is only//
//for leftchannel AUD_ADCDAT data. //
module leftchannel(clk,reset,AUD_ADCLRC_n,AUD_ADCDAT,pDATAOut,en);
input clk; //connect BCLK, module time
input reset; //
input AUD_ADCLRC_n;
input AUD_ADCDAT; //serial data from digital audio interface
output[15:0] pDATAOut; //parallel
output en; // enable output
wire clk;
wire reset;
wire AUD_ADCLRC_n;
wire AUD_ADCDAT;
reg en;
reg [15:0] pDATAOut;
reg [15:0] pDATAOut_temp;
reg [5:0] counter ; //counter for state S2
reg [8:0] counter0; //counter for state S3
reg [1:0] state; //
parameter S0=2'b00, //
S1=2'b01, //
S2=2'b11, //
S3=2'b10; //
always @(negedge reset or negedge clk)
begin
if (!reset)
begin
state <= S0; //
//counter <= 5&#39;b00000;
//counter0 <= 8&#39;b0000_0000;
end
else
begin
case(state) //
S0:
begin
if (AUD_ADCLRC_n == 1)
state <= S0; //
else
state <= S1;
end
S1:
begin
state <= S2;
end
S2:
begin
if (counter == 5&#39;b10000)
state <= S3;
else
state <= S2;
end
S3:
begin
if (counter == 8&#39;b1010_1111)
state <= S0;
else
state <= S3;
end
endcase
end
end
always @ (negedge clk) // (state)
begin
case(state)
S0:
begin
pDATAOut_temp <= 4&#39;h0000;
en <= 1&#39;b0;
end
S1:
begin
en <= 1&#39;b0;
end
S2:
begin
en <= 1&#39;b0;
case(counter)
5&#39;b00000:
begin
pDATAOut_temp[15] <= AUD_ADCDAT;
counter <= counter+5&#39;b00001;
end
5&#39;b00001:
begin
pDATAOut_temp[14] <= AUD_ADCDAT;
end
5&#39;b01111:
begin
pDATAOut_temp[0] <= AUD_ADCDAT;
end
default:
endcase
end
S3:
begin
//if (counter0 == 8&#39;b0000_0000)
begin
en <= 1&#39;b1;
pDATAOut <= pDATAOut_temp;
counter0 <= counter0+8&#39;b0000_0001;
end
//else
//begin
//en <= 1&#39;b0;
// pDATAOut_temp <= 4&#39;h0000;
// pDATAOut <= 4&#39;h0000;
//counter0 <= counter0+8&#39;b0000_0001;
//end
end
endcase
end
endmodule
THANKS FOR every engineers and friends
my e-mail : hans0352@sohu.com
