12747 Discussions
There is c code errors for using performance counter IP, but I can not debug this problem.
GKO00
The followings are my c code, and "perf_print_formatted_report" has c code error... I don't no why...
#include "sys/alt_stdio.h"
#include "stdio.h"
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "altera_avalon_performance_counter.h"
#define SECTION_1 1
int main()
 int count=0;
 int delay;
 alt_putstr("Hello from Nios II!\n");
 PERF_RESET(PERFORMANCE_COUNTER_BASE);
 PERF_START_MEASURING (PERFORMANCE_COUNTER_BASE);
 PERF_BEGIN (PERFORMANCE_COUNTER_BASE,1);
 PERF_END (PERFORMANCE_COUNTER_BASE,1);
 PERF_STOP_MEASURING(PERFORMANCE_COUNTER_BASE);
   perf_print_formatted_report (
  (void *)PERFORMANCE_COUNTER_BASE, // Peripheral's HW base address
  ALT_CPU_FREQ, // defined in "system.h"
  1,
  "1st_test"
 while(1){
 IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE,count);
 delay = 0;
 while(delay<20000000){
 delay++;
 count++;
 /* Event loop never exits. */
 printf("Goodbye from Nios II - returning from main()!\n");
 return 0;
Ahmed_H_Intel1
the code looks fine only you don't have to use these two headers:
#include "stdio.h"
The error is because the tools failed to make the files, I encourage you to follow the following steps to fix this error:
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/embedded/2019/error---makefile-is-not-up-to-date-.html
