Timers
Im new to Nios.
In my system there are 2 timers:timer_0 and timer_1.
Defined as follow in system.h:
* timer_0 configuration
#define
TIMER_0_NAME "/dev/timer_0"
#define
TIMER_0_TYPE "altera_avalon_timer"
#define
TIMER_0_BASE 0x00042400
#define
TIMER_0_SPAN 32
#define
TIMER_0_IRQ 0
#define
TIMER_0_ALWAYS_RUN 0
#define
TIMER_0_FIXED_PERIOD 0
#define
TIMER_0_SNAPSHOT 1
#define
TIMER_0_PERIOD 1
#define
TIMER_0_PERIOD_UNITS "ms"
#define
TIMER_0_RESET_OUTPUT 0
#define
TIMER_0_TIMEOUT_PULSE_OUTPUT 0
#define
TIMER_0_LOAD_VALUE 24999
#define
TIMER_0_COUNTER_SIZE 32
#define
TIMER_0_MULT 0.0010
#define
TIMER_0_TICKS_PER_SEC 1000
#define
TIMER_0_FREQ 25000000
#define
ALT_MODULE_CLASS_timer_0 altera_avalon_timer
* timer_1 configuration
#define
TIMER_1_NAME "/dev/timer_1"
#define
TIMER_1_TYPE "altera_avalon_timer"
#define
TIMER_1_BASE 0x00042420
#define
TIMER_1_SPAN 32
#define
TIMER_1_IRQ 1
#define
TIMER_1_ALWAYS_RUN 0
#define
TIMER_1_FIXED_PERIOD 0
#define
TIMER_1_SNAPSHOT 1
#define
TIMER_1_PERIOD 100
#define
TIMER_1_PERIOD_UNITS "us"
#define
TIMER_1_RESET_OUTPUT 0
#define
TIMER_1_TIMEOUT_PULSE_OUTPUT 0
#define
TIMER_1_LOAD_VALUE 2499
#define
TIMER_1_COUNTER_SIZE 32
#define
TIMER_1_MULT "1.0E-6"
#define
TIMER_1_TICKS_PER_SEC 10000
#define
TIMER_1_FREQ 25000000
#define ALT_MODULE_CLASS_timer_1 altera_avalon_timer
What i want to know is:
  1. When i use the function : alt_alarm_start i see that the system automatically use timer_0 to set the alarm,why timer_0?
  2. What should i do if i want the alarm every 100 micro seconds and still use the function : alt_alarm_start?
I think you may config your timer in sopc builder
and if want to use it in your nios, you may registry it first and then install it
hope this will help
timer_0 must be defined as the system timer by default. You can change it to timer_1 by updating it in the bsp settings in NIOS SBT tool.
The prototype for alarm start is:
int alt_alarm_start
( alt_alarm* alarm,
alt_u32 nticks,
alt_u32 (*callback) (void* context),
void* context )
Think nticks is what you are looking for. You can use it to trigger a callback function after 100us systicks. One the callback is triggered, you can restart the same alarm within the callback itself.
