UART related problem
hello everyone
I am new to using NIOSII processor. I am trying out a simple program as a beginning to my project. I am using UP3 board and am trying to send and receive data through UART port. From the other side i am checking the result through hyperterminal of another PC. I am not able to receive or transmit any data. This might be a problem of pins i have assigned to the UART rx and tx. I have assigned them pins 42 and 47. Is that correct ??
plz help me out.
thnx
sourabh
Hi sourabh,
This is correct for the UP3 Rev. 2 (1C6).
For your initial testing, make sure flow-control is disabled and check your cable. On the UP3, the
DB-9 connector is wired as DCE (e.g. RXD on pin2 and TXD on pin3, etc). Your PC RS-232 port is
also DCE ... so you'll need a NULL modem.
--Scott
what do u mean by NULL Modem??
