Unable to mount using NFS
Hello all .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Sorry , i asked about almost the same point days ago ... but beleive me .. I waisted a lot of time ... and still .. i cant make it work ..
i want to mount a folder from my linux PC to the uClinux.. using NFS ..
i followed what was said to me ..
a strange error came up .. maybe i did not include a certain package while doing the menuconfig
the error is:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
RPC: unable to receive: errno = No route to host[/b]
--- Quote End ---
also when i do telnet to my PC
--- Quote Start ---
telnet: unable to connect to remote host: No route to host[/b]
--- Quote End ---
but i can ping the server from client and vice versa !
i checked the NFS server ..it seems running.. "rpcinfo -p" tells me that many nfs ports are opened .. i have versions 2,3 and 4 running ..
but still cant mount !
and i cant understand !!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
pls help ..
Thanks a lot..
Yours,
Tarek http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
sorry for late. I had a vacation last week.
did you open the firewall on your server?
or try to disable firewall totally.
service iptables stop
--- Quote Start ---
originally posted by hippo@Jul 10 2006, 07:15 AM
sorry for late. i had a vacation last week.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16732)</div>
--- Quote End ---
ok.. i stopped the firewall .. double and even tripple checked that the service is running correctly on the server .. i tried with another PC linux ..
from the other pc i typed :
showmount -e <myIP>
the shared folder appeared after a while .. (about 5 seconds at first..faster next)
but when i tried to mount .. it said" RPC timeout" after a loong while ..
i tried to mount from the uCinux .. it said the following:
--- Quote Start ---
/> mount 192.168.0.122:/home/tarek/Desktop /mnt
mount: RPC: Timed out
mount: nfsmount failed: Bad file descriptor
mount: Mounting blaBla on Blabla failed: Invalid Argument[/b]
--- Quote End ---
Did you see such thing before..? .. sorry ..i am still a starter ..
I had spent about 4 hours till now just trying .. no results.. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
thanks for helping .. and waiting for the next clue from you .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Bye
i also tried the following ..
/> mount -t nfs 192.168.0.122:/home/tarek/Desktop /mnt portmap: server localhost not responding, timed out RPC: failed to contact portmap (errno -5). portmap: server localhost not responding, timed out RPC: failed to contact portmap (errno -5). lockd_up: makesock failed, error=-5 portmap: server localhost not responding, timed out RPC: failed to contact portmap (errno -5). />
also tried the " -o nfsvers=2 " .. the same http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif
--- Quote Start ---
originally posted by tarekeldeeb+jul 10 2006, 01:57 pm--><div class='quotetop'>quote (tarekeldeeb @ jul 10 2006, 01:57 pm)</div>
--- quote start ---
<!--quotebegin-hippo@Jul 10 2006, 07:15 AM
--- Quote End ---
showmount -e <myIP>
--- Quote Start ---
--- Quote End ---
Bye
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16742)</div>
[/b]
--- Quote End ---
You need the -o nolock in mount flags.
mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.1.2:/home/nios2 /mnt/nfs ( eg, server ip 192.168.1.2)
Look in the wiki carefully.
But why you failed to mount nfs from another linux pc?
--- Quote Start ---
originally posted by hippo@Jul 10 2006, 08:08 AM
you need the -o nolock in mount flags.
look in the wiki carefully.
but why you failed to mount nfs from another linux pc?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16745)</div>
--- Quote End ---
i did ... the same error
--- Quote Start ---
--- Quote End ---
i began thinking that the server itself has a problem .. i have fedora core5 .. so i tried the server on a different pc .. having fedora core 4 .. the same results :S
when i type " rpcinfo -p " ..
i can see many prgz.. portmapper,status,nfs,nlockmgrrquotad,mountd ..
all of them have both TCP and UDP versions .. with more than one version..
i am very confused http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
thanks for your reply..
and still waiting ... for the next clue . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
sorry .. for continuous replies..
i tried this
mount -t nfs -o nolock 192.168.0.122:/home/tarek/Desktop /mnt/test
i did not set the rsize or the wsize.. it did NOT give an error ..
but when i tried to " cd /mnt/test " it gave a " permission denied " http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
Darkness inside confusion ,, this is how i feel now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
--- Quote Start ---
i tried  this
mount -t nfs -o nolock 192.168.0.122:/home/tarek/desktop /mnt/test
i did not set the rsize or the wsize.. it did not give an error ..
but when i tried to " cd /mnt/test " it gave a " permission denied "  http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
darkness inside confusion ,, this is how i feel now http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/laugh.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16749)</div>
--- Quote End ---
what is your /etc/exports file ?
/home/nios2 192.168.1.0/255.255.255.0(rw,no_root_squash,sync)
you need the no_root_squas flags,
And try disable selinux in FC4/FC5 with "securify level" config.
Cheer up. you are not alone.
HIPPO ... thanks a LOOOT http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
it appeared to be permission issue ..
i changed the permission of " /home" and "/home/tarek" and "/home/tarek/Desktop" so that everybody can change the files.. it worked ..
about your question: yes i use the flag:
--- Quote Start ---
/home/tarek/Desktop 192.168.0.0/255.255.255.0(rw,no_root_squash,sync)[/b]
--- Quote End ---
but .. a last question please .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
the mount works as read-only.. i need write access to save my outputs on my PC .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
Anyway .. THANKS A LOT .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
you are very close now.
you&#39;d better not use the Desktop dir, it is used by desktop manager.
try
mkdir /home/nios2
chmod -R a+rw /home/nios2
and export /home/nios2,
--- Quote Start ---
you&#39;d better not use the desktop dir, it is used by desktop manager.
try
mkdir /home/nios2
chmod -r a+rw /home/nios2
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16762)
--- quote end ---
--- Quote End ---
i tried it .. i gave the same result !!
i tried making and mounting /uc (i thought the permission of /home had problems)
this also gave the same results http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Hippo .. thanks for your patience ..
could this be a client problem ?
Tarek,
Please take a look at your Linux box&#39;s message log (/var/log/messages or /var/log/nfs, or something like that).
For successful unmounting/mounting of NFS shares, you should see something like the following:
Jul 10 14:30:06 <your server> mountd: authenticated unmount request from <your client>:820 for <your_share> (<your_share>) Jul 10 14:30:32 <your server> mountd: authenticated mount request from <your client>:915 for <your_share> (<your_share>)
NOTE: <your_server>,<your client>, and <your_share> are specific to your system&#39;s configuration.
This is the way I always debug NFS share permissions issues....and it hasn&#39;t failed me yet.
Also, as hippo suggests, please ensure that your /etc/exports file looks something like this, with, perhaps, multiple shares defined.
<your share> <your client>(rw,sync,no_root_squash)
Cheers,
- slacker
I tested again on 2c35 dev board and FC5, but it can read/write nfs mount without problem.
http://nioswiki.jot.com/wikihome/operating...zimage_std_2c35 (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux/zimage_std_2c35
it is the default nios2 kernel config as in my post of uClinux-dist-test.
enabled smc91111 , nfs, and nfs v3.
enabled mount in busybox.
--- Quote Start ---
originally posted by slacker@Jul 10 2006, 11:46 PM
tarek,
please take a look at your linux box&#39;s message log (/var/log/messages or /var/log/nfs, or something like that).
for successful unmounting/mounting of nfs shares, you should see something like the following:
jul 10 14:30:06 <your server> mountd: authenticated unmount request from <your client>:820 for <your_share> (<your_share>) jul 10 14:30:32 <your server> mountd: authenticated mount request from <your client>:915 for <your_share> (<your_share>)
note:  <your_server>,<your client>, and <your_share> are specific to your system&#39;s configuration.
this is the way i always debug nfs share permissions issues....and it hasn&#39;t failed me yet.
also, as hippo suggests, please ensure that your /etc/exports file looks something like this, with, perhaps, multiple shares defined.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16777)</div>
--- Quote End ---
yes i find such messages in var/log/messages but with different port numbers.
and i also double checked the export file
no more ideas?
<<<< FINALLY DONE >>>>
Hippo i tried your zImage .. same bad results.. read only..
so i am sure it is a server issue .. not client problem ..
i tried reading some forums.. and guessed it could be the SElinux ..
and it was http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
I disabled it .. every thing went fine http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hippo and Slacker .. thanks a lot for your warm support http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Thanks everyone
Bye http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
