12686 Discussions
User space application access to Hardware. HPS FPGA bridge
Dear all
I am a newbie on Altera SoC architecture, so I am trying to run a simple C Userspace application on an Arria 10 SoC (attached file custom_software.zip).
The application tries to access a gpio controller (offset adress 0x0000_1000) controller via the hps_i_bridge_lw using a mmap function.
When running using sudo, i got the following error message :
root@linaro-nano:~/sandbox# sudo ./FPGAHPS
[ 1749.499651] Unhandled fault: external abort on non-linefetch (0x818) at 0x760
[ 1749.507198] pgd = ecccc000
[ 1749.509891] [76c30000] *pgd=6df89831, *pte=ff201743, *ppte=ff201c33
The h2f_lw_axi_master seems to be present in the kernel and uboot devicetree.
Also i tried to access the address 0xFF200000 (h2f_lw_axi_master) in the U-boot environment using md/mw commands and it makes U-boot to restart.
http://www.alteraforum.com/forum/attachment.php?attachmentid=12403&stc=1
I must have done something wrong, any ideas ?
Thanks in advance
Mathieu
did you release the bridge from reset, after programming the image to the FPGA?
Hi
On our board, the FPGA is loaded at startup from a flash memory using Active Serial. The resets signal from fpga to hps are hps_f2h_cold_reset_req_reset_n, hps_f2h_warm_reset_req_reset_n, they start at 0 and go high after few clock cycle.
However I haven't seen any signals named lwhps2fpga_bridge_rst_n, which I think is responsible of the lw bridge reset.
I found some hint there : https://lists.rocketboards.org/pipermail/rfi/2015-august/003260.html
I have modified the command for enabling specifically the lw_hps-2-fpga bridge but i got the following errors, i think the address is still protected
In: serial
Out: serial
Err: serial
Model: SOCFPGA Arria10 Dev Kit
Net: dwmac.ff802000
Hit any key to stop autoboot: 0
SOCFPGA_ARRIA10# mw.l 0xffd13500 0x1
SOCFPGA_ARRIA10# mw.l 0xffd13504 0x1
SOCFPGA_ARRIA10# mw.l 0xffd11004 0xffffffff
SOCFPGA_ARRIA10# md.l 0xffd0502c 1
ffd0502c: 0000003f ?...
SOCFPGA_ARRIA10# mw.l 0xffd0502c 0x3d
ffd0502c: 0000003d =...
SOCFPGA_ARRIA10# md.l 0xff200000 1
ff200000:data abort
pc : [<ffe0ecae>] lr : [<ffe0ec8f>]
sp : ffe3be28 ip : ff200000 fp : 00000000
r10: ff200000 r9 : ffe2e310 r8 : ff200000
r7 : 00000001 r6 : 00000004 r5 : 00000004 r4 : 00000001
r3 : ffe0d255 r2 : 00000001 r1 : ffe3be3c r0 : 00000009
Flags: nZCv IRQs on FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
Any hint ?
Thanks for your help
Dear all
I think I have found a begging of a workaround.
If you encounter a similar problem like me, here is the process :
- first of all enable also the standard HPS-2-FPGA bridge in your Qsys system
- follow the same instruction here https://lists.rocketboards.org/piper...st/003260.html
then it is possible to access the FPGA bridge from U-boot
I am able to run a bare metal application and access the registers.
But still not able to do a mmap in Linux userspace (of course with the administrator's rights)
Mathieu
