In nios2, I did not find this file. Where does this file resides or how can I get it from the .elf file?
cd <directory containing elf file>
make <project>.elf.objdump- Mark as New
Remymartin,
You can also check the Window->Preferences->Nios II->"Generate objdump file" box. This will generate the objdump file for every project that is built. It will be placed in your project's build target directory (Debug or Release, usually). Cheers, - slacker
