12620 Discussions
Why I can't boot uclinux kernal in NIOSII?
I created and build a Linux kernel and filesystem project guided by the file "Linux Quick Start Guide" located in :\altera\kits\nios2_60\documents\linux.Then I secelted tools->flash programmer in IDE,and click the apply-->program flash button to download the executable file:build/vmlinux .
After that I download the .sof file into the development board.When it is done,I open Nios II SDK shell and type nios2-terminal in command line.
[SOPC Builder]$ nios2-terminal
The boot information is as follows:
nios2-terminal: connected to hardware target using JTAG UART on cable
nios2-terminal: "ByteBlasterII [LPT1]", device 1, instance 0
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Linux version 2.6.11-uc0 (lq1@lq) (gcc version 3.4.1 (Altera Nios II 5.1 b93))# 23 Mon Aug 14 16:36:53 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line: root=/dev/mtdblock0 ro
PID hash table entries: 128 (order: 7, 2048 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 14720k/16384k RAM, 0k/0k ROM (1228k kernel code, 260k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x821208d0 (irq = 1) is a jtag_uart
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
smc_probe: 50000 Khz Nios
SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6)
eth0: SMC91C11xFD(rev:1) at 0x82110300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07:ed:0b:04:c9
uclinux[mtd]: RAM probe address=0x1174474 size=0x0
Creating 1 MTD partitions on "RAM":
0x00000000-0x00000000 : "ROMfs"
mtd: partition "ROMfs" is out of reach -- disabled
uclinux[mtd]: set ROMfs to be root filesystem
Altera NDK flash (AMD): Found 1 x8 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Altera NDK flash (AMD): CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using Altera NDK partition definition
Creating 4 MTD partitions on "Altera NDK flash (AMD)":
0x00200000-0x00600000 : "romfs/jffs2"
0x00000000-0x00200000 : "loader/kernel"
0x00600000-0x00700000 : "User configuration"
0x00700000-0x00800000 : "safe configuration"
microtronix[mtd]: RAM probe address=0x200000 size=0x0
microtronix[mtd]: set ROMfs to be root filesystem
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
NET: Registered protocol family 17
end_request: I/O error, dev mtdblock0, sector 2
EXT2-fs: unable to read superblock
end_request: I/O error, dev mtdblock0, sector 0
romfs: unable to read superblock
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,0)
Can anyone here explain the problem?
Thank you very much!
make sure File systems->ROM file system support be selected, and
Device Drivers->Memory Technology Devices (MTD)->Mapping drivers for chip access-> Generic uClinux RAM/ROM filesystem support be disabled.
I give the final answer:
Actually, except the kernel project created and programmed into the flash, you
also need to create a root file system and program it into the flash. Please
follow the steps to create the kernel project and file system project according to
the "Linux Quick Start Guide". After build them successfully, open the NiosII
command shell and try to program both the ext_flash.flash and romfs.flash into
flash:
elf2flash --base=0x00000000 --end=0x7fffff --reset=0x0 --input=vmlinux
--output=ext_flash.flash --boot
=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec
nios2-flash-programmer --base=0x0000 ext_flash.flash
nios2-flash-programmer --base=0x0000 romfs.flash
The ext_flash.flash is generated through the elf2flash command. The input file is
vmlinux.bin in the "build" folder under kernel project. The romfs.flash is
generated automatically after building the file system project. Please note to go
to the correct directory and input the commands.
