Yocto and Build Linux
According to the docs:
http://www.rocketboards.org/foswiki/documentation/alterasocdevelopmentboardyoctogettingstarted
bitbake virtual/kernel and bitbake linux-altera are identical. For me the first command works but the second
does not. I get this error when running linux-altera
ERROR: Function failed: Fetcher failure for URL: 'git://git.rocketboards.org/linux-socfpga.git;protocol=http;branch=socfpga-3.11-rel'. The command git ls-remote http://git.rocketboards.org/linux-socfpga.git socfpga-3.11-rel gave empty output unexpectedly
Anyhow, the second works but then I get no socfpga_cyclone5.dtb after a call to bitbake altera-image.
Any ideas what to do?
EDIT:
Actually, this is the error:
ERROR: Multiple .bb files are due to be built which each provide virtual/kernel (/home/bobo/yocto/meta-altera/recipes-kernel/linux/linux-altera_3.11.bb /home/bobo/yocto/meta-altera/recipes-kernel/linux/linux-altera-dist.bb). This usually means one provides something the other doesn't and should.
The "Fetcher failure for URL: ..." error is due to the 3.11 branch being actually named "socfpga-3.11", without the trailing "-rel".
To solve it I edited the 2nd line of file "~/altera-yocto/meta-altera/recipes-kernel/linux/linux-altera.inc" from:
SRC_URI = "git://git.rocketboards.org/linux-socfpga.git;protocol=http;branch=socfpga-${PV}-rel
to
Regarding the second error "Multiple .bb files ..." I came here looking for a solution to that :) I can't get a dtb either!
